Posts: 21,129 Threads: 580 Likes Received: 8,904 in 6,584 posts Likes Given: 1,424 Joined: Jun 2018 Reputation: 784 13-Sep-2019, 09:14 PM (This post was last modified: 29-Sep-2019, 08:22 AM by SnowLeopardFPV. Edit Reason: Added the alternative solution for when the "Roll Back Driver" button is greyed out. ) If you recently started getting Joystick connectivity issues with your favourite simulator when using a FrSky or Jumper TX as a joystick device via USB then and are tearing your hair out, it seems that Microsoft broke something in the new libusb-win32 drivers that were rolled out a few days ago in one of the latest windows updates. See the following video for how to fix the issue. This fix is for any of the simulators, not just VelociDrone. If the "Roll Back Driver" button is greyed out then see the following alternative solution for that... https://batcavegames.freshdesk.com/suppo...op-working And for those who prefer to read text than watch a video, the Liftoff Team have produced a PDF document detailing the same fix HERE. Posts: 14 Threads: 2 Likes Received: 0 in 0 posts Likes Given: 1 Joined: Sep 2019 Reputation: 0 I'm was about to lose my friggin mind! Thank you for the help. If roll back driver is greyed out, check the Youtube page for a link on how to manually roll it back. Back in the game.......woot! The fact that there's a highway to hell and only a stairway to heaven says a lot about the anticipated traffic numbers...... • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 (13-Sep-2019, 10:11 PM)Rugaru Wrote: I'm was about to lose my friggin mind! Thank you for the help. If roll back driver is greyed out, check the Youtube page for a link on how to manually roll it back. Back in the game.......woot! Hey Rugaru, welcome to the forum! Lot's of good stuff here - check it out and don't be a stranger! • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 13-Sep-2019, 10:34 PM (This post was last modified: 13-Sep-2019, 10:35 PM by Oscar.) You must be reading my mind! I was just about to ask here to see if anyone is having this issue! I've been getting tons of queries on this! Thanks so much Snow! • Posts: 14 Threads: 2 Likes Received: 0 in 0 posts Likes Given: 1 Joined: Sep 2019 Reputation: 0 (13-Sep-2019, 10:18 PM)sloscotty Wrote: Hey Rugaru, welcome to the forum! Lot's of good stuff here - check it out and don't be a stranger! Thank you sir, much obliged! I started down the FPV rabbit hole back in 2017 then life got in the way so I couldn't get away and fly as much. With so many brushless toothpicks out now I wanted to get back into it and start flying around and near the house some more. Tiny whoops scratched that itch for a while, but lacked the power I was enjoying in that first 250mm I built courtesy of Oscar website. Wealth of information......... This technology has changed so fast though that I'm sure I'll have lots of questions...............been a while since I've engaged in any forums, so I'm looking forward to chatting with everyone. Cheers! The fact that there's a highway to hell and only a stairway to heaven says a lot about the anticipated traffic numbers...... • Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 Just had this problem and wanted to confirm this video was in this forum its a life saver. • Posts: 1,312 Threads: 50 Likes Received: 832 in 504 posts Likes Given: 372 Joined: Jul 2018 Reputation: 51 Did MS roll it back? I've not had any problems in Velocidrone with a QX7 and a fresh Win10 install. The ground is for dead people. • Posts: 21,129 Threads: 580 Likes Received: 8,904 in 6,584 posts Likes Given: 1,424 Joined: Jun 2018 Reputation: 784 25-Sep-2019, 10:42 AM (This post was last modified: 25-Sep-2019, 11:44 AM by SnowLeopardFPV. Edit Reason: I meant 17th September not August. Now corrected. ) (25-Sep-2019, 09:43 AM)Banelle Wrote: Did MS roll it back? I've not had any problems in Velocidrone with a QX7 and a fresh Win10 install. I just checked my VS Enterprise subscription download area and the latest available Windows 10 ISO is build 1809 which was published on 17th September. Assuming you used that latest version then it's possibly that the update patch affecting the libusb-win32 drivers didn't quite make it into that updated ISO (or they chose not to include the very latest patches in that release) which means you will likely end up getting it via one of the automatic updates in the coming weeks. MS usually roll out updates in batches to regions so they don't screw everyone in the world up at the same time. Maybe PCs on UK IP addresses haven't yet been allocated the update. Either that or they already fixed the problem in a superseding patch which has already been rolled out. I haven't run VelociDrone for a while so I don't know if my PC has been affected yet. I guess I'll find out soon because flying season here is almost over so I'm going to have to break out the sim again soon. • Posts: 909 Threads: 59 Likes Received: 543 in 318 posts Likes Given: 730 Joined: Nov 2018 Reputation: 26 I just did a fresh install of Win10Pro last week and had to roll back the driver. V 10.0.18362 I am really glad that you had posted this and I had read it before the install Thank you sir Scott • Posts: 54 Threads: 5 Likes Received: 13 in 13 posts Likes Given: 11 Joined: Sep 2019 Reputation: 0 Was about to enter a question on this forum. Video did the trick • Posts: 321 Threads: 51 Likes Received: 123 in 88 posts Likes Given: 164 Joined: Nov 2017 Reputation: 6 Yooooo! Thanks so much for the help! I was about to reinstall Windows if it wasn't for your help!!! • Posts: 223 Threads: 23 Likes Received: 91 in 53 posts Likes Given: 126 Joined: Aug 2019 Reputation: 1 Ouh god.. I spent whole day figuring this out, flashed my OpenTX (had to be done anyways), and only now found out in LiftOff steam discussions about this fix. Even being here everyday, I some how managed to not see this topic. Haha, thanks! • Posts: 3 Threads: 0 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Sep 2019 Reputation: 0 The Roll Back Driver option is disabled for me. Everything else is exactly as you described except for that. So, any suggestions on how to roll back the driver without that button? • Posts: 21,129 Threads: 580 Likes Received: 8,904 in 6,584 posts Likes Given: 1,424 Joined: Jun 2018 Reputation: 784 29-Sep-2019, 08:19 AM (This post was last modified: 29-Sep-2019, 08:23 AM by SnowLeopardFPV.) (29-Sep-2019, 08:14 AM)DSMagic Wrote: The Roll Back Driver option is disabled for me. Everything else is exactly as you described except for that. So, any suggestions on how to roll back the driver without that button? Yes, see the following link for a solution to that I just added the same link to the first post in case anyone else has the same issue so they don't have to scroll down to this post. https://batcavegames.freshdesk.com/suppo...op-working • Posts: 3 Threads: 0 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Sep 2019 Reputation: 0 (29-Sep-2019, 08:19 AM)SnowLeopardFPV Wrote: Yes, see the following link for a solution to that I just added the same link to the first post in case anyone else has the same issue so they don't have to scroll down to this post. https://batcavegames.freshdesk.com/suppo...op-working Thank you, this is progress but I'm not out of the woods yet. This only partially worked. Now simulator thinks I'm moving the joysticks like a madman even when I'm not touching them. Even when I play with the settings, there's something happening that's out of control. • |
