05-Sep-2020, 12:28 AM
I have recently bought a UR85 (crazybee f4 pro V2 without build in receiver) and a seperate receiver xr602t-a.
After conecting everythng up and setting it up in betaflight i could not arm. I checkd it In betaflight status tab and saw a message calibrating msp.
If i unplug The batery and then connect the usb cable to my drone and laptop, i can calibrate in betaflight and arm, if i plug in The batery while the usb cable is stil pluged in and after that if i remove The usb cable i can arm and fly, but as soon as i unplug the battery and plug The battery again it wont calibrate and also wont arm anymore.
So i have to connect to betaflight with usb and calibrate otherwise i can not arm.
And also when The battery is pluged in and The calibrating is not working, in betaflight the 3D model is acting strange, The yaw is not working when i turn my drone the roll and pitch are working on The model.
Does any one now What The problem is??
