Hey guys, new here in this forum, fairly new to FPV.
After a recent crash indoor I have a problem with one of my motors on my Moblite6. It won't spin when armed.
But here comes the catch, this is not always the case.
50% of the time it won't spin, but with a little push of my finger (one or two clicks), it begins spinning again. In this state flying is possible without any disadvantages.
40% of the time it won't even start spinning with that push. Then only disarming and trying again helps.
10% of the time it spins without any problems.
I havent found anything like this online, just that it won't spin in any case or it won't spin in the same speed as the other motors.
What I did until now:
That I will try on the weekend, if noone has any advice for me. If you have an idea, please share it, I am getting desperate.
Thanks in advance
- checking in Betaflight Configurator, everything is normal. On the motor tab the sliders work with the other 3, with the faulty one it is the same percentages as above, nothing different than without a PC
- Measuring the soldering connections at the board with a multimeter. I have a connection between any 2 of the 3 cables to the faulty motor.
- I tried increasing the idle value, did not change anything
- Opend the motor to check for any dirt or something like that, nothing, same problem as before.
Thanks in advance
