22-Jan-2016, 02:58 PM
Hello.
There is UDI U941 I was presented (actually, this is what caused me to dive into quadcopter world!):
After some flying and drowning it in the river near my house ( from onboard camera) I removed the camera module, which was dead anyway.
The bigger problem with this quad was that it was very sensitive to the quality of props - the more props were damaged, the more vibration caused gyro to drift. As it can be flown only in stabilize mode, drifting gyro required to recalibrate often (every 1-2 mins!).
So I decided to make my own frame for it. The main goal is to fix controller on foam to prevent vibrations from causing gyro drift. I have a foamed PVC sheet, it is light and strong and it can easily be cut with the knife. So I decided to use it as a material. This is first try:
And assembled:
Despite it looks pretty terrible, it was not much heavier that original frame, so it was able to fly. The initial problem was solved - gyro was no more drifting.
But... as far as you start improving something, it very hard to stop, isn't it?
So, I thought how I can make frame better. And, as I was building the 250 quad at that time, I wanted to make this lighter frame to be as cheap as possible too.
As the material I took same PVC sheet and bought one 2mm carbon rod. I wanted 3mm initially, but only 2mm were available here.
So, this is how it expected to look:
There is platform in the center and motormounts on the edges of rods are from PVC, and X is rods.
This is first step - the motormouns are still one part with the center plate to be able to drill holes for rods.
After that I cut the rods, inserted them into drilled holes and put epoxy in to secure rods in holes:
After 24 hours I cut unneeded PVC out:
And there is build on new frame:
I'm very happy with it, it very light (unfortunately I can't say how exaclty - the weight of frame is comparable to the measuring error of my kitchen digital scales) and very cheap (it costed me about 3$ for materials).
And assembled:
