Threads: 2
Likes Received: 3 in 3 posts
Likes Given: 9
0 18-Oct-2023, 01:34 PM (This post was last modified: 18-Oct-2023, 09:40 PM by Alfonso Gordon.) Hey all,
Has anyone had any luck with getting 4 bolt motors to work on a mob 7 v3 frame made for 3 bolt motors?
I've got a betafpv 75x frame that's had one to many crashes, ordered a couple of the mob 7 frames but only noticed after i received them that they are for 3 bolt motors.
Would be nice to use them, if not they can go in the box for a rainy day project.
Edit: I can't type
Threads: 125
Likes Given: 99
388 18-Oct-2023, 03:40 PM (This post was last modified: 18-Oct-2023, 08:46 PM by voodoo614.) As long as three of the holes lines up, you should be good to go. But the spacing on the Mob 7 frame might make it impossible for 4 holes motor mount.
Threads: 172
Likes Given: 4,718
100 sadly that frame doesnt match, its the strange sort of choices by betafpv; no pne else on the marked does 4hole mount with m1,4 screws... there are much things done by betafpv for incompatibility between their üroducts and common way we build
i would suggest to gets ome decent happymodel 3 screw motors :-)
Threads: 6
Likes Received: 38 in 32 posts
Likes Given: 48
1 The best way is to use a little brain before purchasing. I design my setups for many months in my head. This way I'll end up with a lot of things that are side thoughts and that I'm interested in checking out.
Threads: 2
Likes Given: 9
0 Thanks for the replys all! I've got the right ones on order now. Used one of the mob 7 frames i had as a test for dying, so i now have a blue/purple mob 7 frame i think i'll sell. I think my 75x frame might have a few more crashes left in it before the others arrive.
Threads: 74
Likes Received: 1,336 in 996 posts
Likes Given: 771
41 I'm looking to do something similar in a few weeks. I want to recreate the Geelang Anger 75 for shit and giggles. The motors use a 9x9 mount pattern so might need to use a custom frame. Worst case I need a custom 75mm carbon fibre frame which may not exist. Maybe time to learn how to design frames in autocad.
Try Not, Do or Do Not
- Yoda
Threads: 25
Likes Received: 137 in 107 posts
Likes Given: 90
3 Ha, reminds me of the RotorX rx122 but with 2" props instead of 3.
