Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 2
0 Hi!
My drone stopped calibrating the gyro out of nowhere, I didn't crash it and I found out that sometimes, if I wait without touching it for about 1 to 5 minutes it just calibrates, I have no gps so it isn't trying to find satellites or anything like that, does someone know if it's in its final days or it might be something else?
Thanks
Threads: 118
Likes Received: 1,411 in 728 posts
Likes Given: 1,069
41 Have you connected to betaflight configurator and checked the gyro there, initialised it, etc? I think there is a joshua bardwell video on checking the health of the gyro.
The following 1 user Likes ph2t's post:1 user Likes ph2t's post • Muga Posts: 1,490
Threads: 92
27 Only 3 things I know affecting gyro.
1. Bad 3.3V. Voltage regulator dying or caps broke off from board.
2. Really bad luck. Broken.
3. ??
Threads: 38
Likes Given: 430
118 What FC are we talking about here?
Some manufacturers are notorious for using sub-standard components.
Threads: 92
27 Some mfcr are much worse than others with QA.
FrSky - I'm looking at you - I had oscillators and capacitors peel off with double-sided tape from the receiver.
Sometimes tiny SMD parts are just barely hanging on. Sometimes, you accidentally lightly chip a capacitor, and with bad luck its broken. Or even just the flexing of the board in flight or heat from soldering.
I started this hobby with 2 buckets. 100% working parts. And 1-2 broken/DOA parts.
But, after years, now there is a quickly growing 3rd bucket...
"Works most of the time, but glitches out or something.. I dunno.. do I wanna risk it?"
Threads: 172
Likes Given: 4,721
100 about noise, a capacitator should be checked/replaced or additional capacitance added. i would try that first, the relationship with 16v sounds like it could help.
