Posts: 71 Threads: 12 Likes Received: 3 in 2 posts Likes Given: 30 Joined: Oct 2017 Reputation: 0 23-Apr-2019, 09:58 PM (This post was last modified: 23-Apr-2019, 09:59 PM by Sebalos.) Hi guys, I have accidentally zeroed settings of my eachine trashcan. I have Frsky receiver. Can anybody share file with betaflight configuartion backup? I would like to restore original settings. • Posts: 21,245 Threads: 586 Likes Received: 8,962 in 6,632 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 787 23-Apr-2019, 10:41 PM (This post was last modified: 16-Nov-2019, 03:35 PM by SnowLeopardFPV. Edit Reason: Stripped out unnecessary empty sections. ) Here you go. This is a "diff" I did of the original factory configuration when I first got my Trashcan (FrSky version) before I made any changes... Code: # version # Betaflight / CRAZYBEEF4FR (C4FR) 4.0.0 Dec 11 2018 / 01:44:17 (3b479f92d) MSP API: 1.41 board_name CRAZYBEEF4FR manufacturer_id mcu_id 003400433437510432383735 signature # reset configuration to default settings defaults nosave # name name Trashcan # feature feature -ANTI_GRAVITY feature -DYNAMIC_FILTER feature MOTOR_STOP feature LED_STRIP # map map TAER1234 # serial serial 0 2048 115200 57600 0 115200 # led led 0 4,7::CO:2 led 1 5,7::CO:2 led 2 6,7::CO:2 led 3 7,7::CO:2 led 4 8,7::CO:2 # aux aux 0 0 0 1300 2100 0 0 aux 1 1 1 1200 1550 0 0 aux 2 28 1 1550 2100 0 0 aux 3 35 2 1550 2100 0 0 # master set motor_pwm_protocol = DSHOT600 set vbat_min_cell_voltage = 29 set vbat_warning_cell_voltage = 30 set ibata_scale = 1175 set yaw_motors_reversed = ON set osd_warn_esc_fail = OFF set osd_vbat_pos = 2102 set osd_rssi_pos = 2083 set osd_tim_1_pos = 54 set osd_tim_2_pos = 2134 set osd_flymode_pos = 2456 set osd_throttle_pos = 2423 set osd_crosshairs_pos = 2253 set osd_current_pos = 2400 set osd_mah_drawn_pos = 2432 set osd_craft_name_pos = 2443 set osd_warnings_pos = 329 set osd_disarmed_pos = 2346 set vtx_band = 5 set vtx_channel = 8 set vtx_power = 3 set vtx_freq = 5917 set frsky_spi_tx_id = 140,7 set frsky_spi_offset = -26 set frsky_spi_bind_hop_data = 2,7,12,17,22,27,32,37,42,47,52,57,62,67,72,77,82,87,92,97,102,107,112,117,122,127,132,137,142,147,152,157,162,167,172,177,182,187,192,197,202,207,212,217,222,227,232,0,0,0 set frsky_x_rx_num = 7 # profile profile 0 # rateprofile rateprofile 0 set roll_rc_rate = 120 set pitch_rc_rate = 120 set yaw_rc_rate = 130 set roll_srate = 75 set pitch_srate = 75 set yaw_srate = 80 # save configuration save
Posts: 71 Threads: 12 Likes Received: 3 in 2 posts Likes Given: 30 Joined: Oct 2017 Reputation: 0 Thanks !!! • Posts: 2 Threads: 0 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Nov 2019 Reputation: 0 I made the same mistake do you happen to have this in the FLYSKY version ?? • Posts: 21,245 Threads: 586 Likes Received: 8,962 in 6,632 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 787 (16-Nov-2019, 01:24 AM)Ace Ventura4443 Wrote: I made the same mistake do you happen to have this in the FLYSKY version ?? I don't have an actual dump of diff from the Flysky version of the Crazybee F4 Pro used in the Eachine Trashcan but it is going to be the same as the one from the FrSky version with a few minor differences. I've constructed you a "diff" file below that containing all the settings that will be very close to (if not exactly the same as) the original factory settings. Just run this into the CLI and it should restore the factory settings. You will need to re-bind the SPI receiver on the board to your transmitter once you've applied these settings. Code: # version # Betaflight / CRAZYBEEF4FS (C4FS) 4.0.0 Dec 11 2018 / 01:08:39 (3b479f92d) MSP API: 1.41 board_name CRAZYBEEF4FS manufacturer_id mcu_id 004700173437511430353933 signature # reset configuration to default settings defaults nosave # name name Trashcan # feature feature -ANTI_GRAVITY feature -DYNAMIC_FILTER feature MOTOR_STOP feature LED_STRIP # serial serial 0 2048 115200 57600 0 115200 # led led 0 4,7::CO:2 led 1 5,7::CO:2 led 2 6,7::CO:2 led 3 7,7::CO:2 led 4 8,7::CO:2 # aux aux 0 0 0 1300 2100 0 0 aux 1 1 1 1200 1550 0 0 aux 2 28 1 1550 2100 0 0 aux 3 35 2 1550 2100 0 0 # master set motor_pwm_protocol = DSHOT600 set vbat_min_cell_voltage = 29 set vbat_warning_cell_voltage = 30 set ibata_scale = 1175 set yaw_motors_reversed = ON set osd_warn_esc_fail = OFF set osd_vbat_pos = 2102 set osd_rssi_pos = 2083 set osd_tim_1_pos = 54 set osd_tim_2_pos = 2134 set osd_flymode_pos = 2456 set osd_throttle_pos = 2423 set osd_crosshairs_pos = 2253 set osd_current_pos = 2400 set osd_mah_drawn_pos = 2432 set osd_craft_name_pos = 2443 set osd_warnings_pos = 329 set osd_disarmed_pos = 2346 set vtx_band = 5 set vtx_channel = 8 set vtx_power = 3 set vtx_freq = 5917 # profile profile 0 # rateprofile rateprofile 0 set roll_rc_rate = 120 set pitch_rc_rate = 120 set yaw_rc_rate = 130 set roll_srate = 75 set pitch_srate = 75 set yaw_srate = 80 # save configuration save
• Posts: 2 Threads: 0 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Nov 2019 Reputation: 0 (16-Nov-2019, 03:38 PM)SnowLeopardFPV Wrote: I don't have an actual dump of diff from the Flysky version of the Crazybee F4 Pro used in the Eachine Trashcan but it is going to be the same as the one from the FrSky version with a few minor differences. I've constructed you a "diff" file below that containing all the settings that will be very close to (if not exactly the same as) the original factory settings. Just run this into the CLI and it should restore the factory settings. You will need to re-bind the SPI receiver on the board to your transmitter once you've applied these settings. Code: # version # Betaflight / CRAZYBEEF4FS (C4FS) 4.0.0 Dec 11 2018 / 01:08:39 (3b479f92d) MSP API: 1.41 board_name CRAZYBEEF4FS manufacturer_id mcu_id 004700173437511430353933 signature # reset configuration to default settings defaults nosave # name name Trashcan # feature feature -ANTI_GRAVITY feature -DYNAMIC_FILTER feature MOTOR_STOP feature LED_STRIP # serial serial 0 2048 115200 57600 0 115200 # led led 0 4,7::CO:2 led 1 5,7::CO:2 led 2 6,7::CO:2 led 3 7,7::CO:2 led 4 8,7::CO:2 # aux aux 0 0 0 1300 2100 0 0 aux 1 1 1 1200 1550 0 0 aux 2 28 1 1550 2100 0 0 aux 3 35 2 1550 2100 0 0 # master set motor_pwm_protocol = DSHOT600 set vbat_min_cell_voltage = 29 set vbat_warning_cell_voltage = 30 set ibata_scale = 1175 set yaw_motors_reversed = ON set osd_warn_esc_fail = OFF set osd_vbat_pos = 2102 set osd_rssi_pos = 2083 set osd_tim_1_pos = 54 set osd_tim_2_pos = 2134 set osd_flymode_pos = 2456 set osd_throttle_pos = 2423 set osd_crosshairs_pos = 2253 set osd_current_pos = 2400 set osd_mah_drawn_pos = 2432 set osd_craft_name_pos = 2443 set osd_warnings_pos = 329 set osd_disarmed_pos = 2346 set vtx_band = 5 set vtx_channel = 8 set vtx_power = 3 set vtx_freq = 5917 # profile profile 0 # rateprofile rateprofile 0 set roll_rc_rate = 120 set pitch_rc_rate = 120 set yaw_rc_rate = 130 set roll_srate = 75 set pitch_srate = 75 set yaw_srate = 80 # save configuration save
Thank you so much. I got it working but I think maybe I did somthing to my esc's? I tryed flashing the firm ware for the esc's on BLheli and now whenever I arm the copter the motors spool up a little bit? It will fly ok and everything seems to work but it won't stop idling on the ground...motors just sit there spinning at a very low speed...any ideas? • Posts: 21,245 Threads: 586 Likes Received: 8,962 in 6,632 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 787 (16-Nov-2019, 04:59 PM)Ace Ventura4443 Wrote: Thank you so much. I got it working but I think maybe I did somthing to my esc's? I tryed flashing the firm ware for the esc's on BLheli and now whenever I arm the copter the motors spool up a little bit? It will fly ok and everything seems to work but it won't stop idling on the ground...motors just sit there spinning at a very low speed...any ideas? Yes, that will likely be because you switched off MOTOR_STOP (it's on the right-hand side of the "Configuration" tab in Betaflight Configurator). With MOTOR_STOP switched off, when you arm the quad it will spin the motors at idle. While not strictly a necessity on a tiny whoop with pretty harmless blades, having the motors spin when armed on any quad (especially the large ones with unguarded props) can be a useful safely feature which lets you know visually when your quad is armed because the motors are spinning. If the idle is still set at 4.5 then I found that to be a little slow for the Trashcan so you might want to increase it to 6 which I found works much better. If you want confirmation of your settings, run the "dump" command in the CLI and copy/paste the results back here. We can then take a look at what settings you've applied. • |
