Threads: 582
Likes Received: 8,924 in 6,601 posts
Likes Given: 1,425
786 08-Feb-2022, 09:04 PM (This post was last modified: 08-Feb-2022, 09:08 PM by SnowLeopardFPV. Edit Reason: Added "EDIT" line. ) It almost looks like there is an actual gap in the design so the printer hasn't even attempted to join/fuse those parts of the base to the main camera housing body.
Do you have a link to the STL file you are trying to print?
EDIT: That is also quite bad stringing. Do you always get that result when printing TPU on your Ender 3? Sainsmart TPU usually prints quite well if you use the correct profile so I'm surprised it is producing that amount of stringing, unless your spool of TPU has just been left out in the open and has absorbed a load of moisture from the air.
Threads: 99
Likes Received: 5 in 5 posts
Likes Given: 13
0 Thank you so much Snow, I really apreciatte it <3
