29-May-2021, 07:59 AM
Here are my Top 5 Tools. Let me know your Top 5 tools are.
Top 5 Tools for FPV |
29-May-2021, 07:59 AM Here are my Top 5 Tools. Let me know your Top 5 tools are. 29-May-2021, 06:38 PM I agree with you for the most part. But I think a smoke stopper should be included somewhere. 01-Jun-2021, 08:49 PM Battery charger is a must, but I don't consider it a tool, but more of a drone accessory. Some drones even come with one. Smoke stopper, but again, I don't really consider this a tool, but rather an accessory since you don't actually "build" with it. 1. Soldering iron, but it doesn't need to be expensive; mine is a $ 15 dollar US AMAZON special with the wheel taped at 425 C degrees. 2. Metric Allen wrench tools with handles; what ever brand or name you want doesn't matter. 3. Small, normally closed tweezers with long tips. These are great...indispensable for me. 4. Xacto Knife. Must have. 5. Heat gun. {although truth is a match will work if you have to}. Plus... Small side cutters. Needle nosed pliers. Punch or Awl. Small hand drill with 2mm bit. Deep socket nut driver with handle {pliers will work if you don't have one}. 15-Jun-2021, 02:05 AM Tweezers Multimeter Electric screwdriver GOOD soldering equipment. Iron is probably the least important part except for a proper tip. 8mm ratchet wrench/socket for props. Not in any specific order, but i would be really sad if i had to give any of these up, the rest of my tools i can probably do without, or consider "obvious", i.e. pliers, hex keys/drivers etc. 15-Jun-2021, 05:40 AM Reverse tweezers! Just amazing, should have got some years ago. Hold wires effortlessly and the bonus of not burning your fingers! 15-Jun-2021, 11:47 AM (15-Jun-2021, 05:40 AM)Kevin2112 Wrote: Reverse tweezers! Just amazing, should have got some years ago. Hold wires effortlessly and the bonus of not burning your fingers! H Kevin, Yeah, that is item #3 in my list; normally closed {reverse} tweezers...indispensable...love them For me, they work much better than normal tweezers. In fact, I have 2 90 degree angle ones, a 45 degree angle one, and a straight {really straight} one. The straight on is great for starting M2 nuts {which I can barely hold with my fingers}. The top 5 is a very short list. My list of tools far exceeds that. Plus, there are a lot of little things that are not really tools, but help in the process; such as the blue "tak" putty...the best thing I have found for holding wire and boards while soldering them...MUCH Better than "helping hands", clips, clamps, or anything else. I also keep an assortment of glues and adhesives. Everything from House Hold DUCO cement, to 2 part epoxies, to UV cured BONDIC {this is GREAT stuff, I use it all the time}. When soldering, that "brillo" {wire hair} thing is great, but I also use a wet paper towel to clean the iron tip. Then there is the fan to pull fumes and smoke away. Another thing that I wouldn't call a tool, but very helpful, is a small metal stand to hold the monitor from my Viper goggles to use on the bench when checking the video feed. So...the top 5 only get you started...the REAL list is much longer... |
How To Corner FPV Like a Pro - Cornering Drones | mattyfleischfpv | 0 | 265 | 31-Jan-2024, 07:36 PM Last Post: mattyfleischfpv | |
Better FPV throttle control - Improve your stick movement FAST | mattyfleischfpv | 1 | 297 | 31-Jan-2024, 02:15 AM Last Post: Pathfinder075 | |
FPV Angle Mix Mode. | AngryPepper | 2 | 5,126 | 02-Nov-2021, 07:18 PM Last Post: AngryPepper | |
FPV Video --> TX16s LCD | raspberrypi33 | 5 | 1,333 | 28-Aug-2021, 05:18 PM Last Post: MrSolo | |
OSD Add Picture-in-Picture to FPV | BrickedAndroid | 6 | 1,471 | 30-Jun-2021, 09:38 PM Last Post: BrickedAndroid |
