This is my 2nd toothpick project. A backyard 2S flyer. Based on the same frame as my first attempt.
2S 520mAh GNB pack. GIF speed is a little faster actual speed. Not much though!
Some takeaways..
The pickle frame is a bare bones kits, you get the basics. The provided camera "canopy" is a few thin strips of TPU - I used a design from thingiverse printed in TPU instead. It is a very cheap frame though and you can buy a few without hurting the pocket.
The JHEMCU flight controller is the cheapest F4 whoop AIO controller on banggood, it works a treat but is only rated to 2S so best paired with high KV motors if you want some speed out of it. The motors pads are hell, very close and very small. You are provided with motor plugs to solder on the board if you want but I direct soldered.
The racerstar motors are cheap but perform well. The top end doesn't have much variance but the low end controll on the throttle is pretty good. They seem to be able to turn tri-blade props pretty well. I haven't had much time to compare with 65mm bi-blades but I will put them on soon.
I forgot the name of the clone RX. it was like $10 on banggood. It has diversity RX and telemetry and a usuable distance of approx 50m. lol. Shit as. I will change it out soon.
Unlike the RX, my choice of VTX was better. The HGLRC nano VTX is smaller than my thumbnail. Works well and great video when paired with the dipole antenna that it comes with. 25 and 50mW is available.
Running RPM filters on 16.77 BLHELI_S firmware. Have moved the filter sliders up 2-3 notches and no fly-aways and warm motors at most.
Working on PIDS.
Will post builds pics soon. This was a real bugger to build. Still balancing karma by flying it after work each day before I post more pics, lol..
cheers,
ph2t.
- LeDrone club pickle frame - 65mm / 2.5" prop size
- JHEMCU Play F4 AIO FC with 5A BLHeli_S 1-2S 4in1 ESC
- RacerStar 1103B - 10,000KV motors
- crappy clone frsky RX with diversity antennas and telemetry
- HGLRC nano VTX
- Runcam racer nano 2 camera
- GEMFAN 2.5" props (I think, lost the packet)
Some takeaways..
Working on PIDS.
cheers,
ph2t.
