Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 30-Aug-2021, 01:30 AM (This post was last modified: 30-Aug-2021, 01:31 AM by the.ronin.) I need arm measurements lol (see what I did there? ) If you just so happen to be bored, have a ruler or digital caliper and a drone within arm's reach (damn, I'm on a roll, I know), please consider taking a measurement of the thickness and width at the middle of the arm. Doesn't have to be precise at all. I also need to know the prop size that goes with those arms. I kept this in the Mini Quad forum since I'm mostly interested in 3" to 5" quads. So something like (from an Apex): 5" props, 6mm thick, 12mm wide For science!! Thanks!! • Posts: 4,550 Threads: 38 Likes Received: 1,245 in 1,064 posts Likes Given: 430 Joined: Aug 2020 Reputation: 118 TBS Source One v3: Prop size: 5.1" Thickness: 4mm Width: 15mm Posts: 590 Threads: 16 Likes Received: 176 in 149 posts Likes Given: 26 Joined: Jun 2021 Reputation: 8 Taken from about the middle of the arms with my caliper: 2.5" GepRC Phantom HD Width 7.5mm Height 3.1mm 3" Crux3 Width 4mm Height 2.5mm 3" Babytooth Width 5.75mm Height 2mm 3.5" Avant Avio Width 6mm Height 4mm 5" GepRC Mark4 HD5 Width 10.5mm Height 5.1mm Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 Thanks guys and please keep em comin'. Or I'm gonna do more dad jokes ... to twist your arm. • Posts: 4,073 Threads: 75 Likes Received: 2,548 in 1,858 posts Likes Given: 3,949 Joined: May 2021 Reputation: 121 (31-Aug-2021, 12:16 AM)the.ronin Wrote: Thanks guys and please keep em comin'. Or I'm gonna do more dad jokes ... to twist your arm. If you do some more dad jokes, I’ll set an alarm/reminder to measure all of my 3”+ frames later today. Okay, I already set a reminder, but I’d still like some jokes. Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. • Posts: 6,096 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,725 Joined: Feb 2019 Reputation: 100 im shy to start mesurements, i have a lot unusal frames like ultralight ones... 2,5mm 5inch frames with 5mm wideness xD for what exactly do you need that mesurements? are you intressted in unusual settup frames? regardless kind of quad unibody/splitarm and purpose spacy freestyle frame, cruiser or leightweight racer/basher? • Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 (31-Aug-2021, 02:15 PM)hugnosed_bat Wrote: for what exactly do you need that mesurements? are you intressted in unusual settup frames? regardless kind of quad unibody/splitarm and purpose spacy freestyle frame, cruiser or leightweight racer/basher? Just trying to build up a set of data points is all. I'm coming to appreciate that so much of a frame's performance is informed by the arms. And hey, even if it is totally unusual, if it works, then it's good data. (31-Aug-2021, 01:53 PM)Lemonyleprosy Wrote: Okay, I already set a reminder, but I’d still like some jokes. Well arm't you the clever one! Posts: 164 Threads: 10 Likes Received: 95 in 71 posts Likes Given: 172 Joined: Dec 2020 Reputation: 4 Here's what I have at hand... BetaFPV X-Knight 4" 5x4mm 4" Hyperlite Pyrocube [vertical box frame] 12x2mm 5" Martian 220 17x4mm 5" Posts: 6,096 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,725 Joined: Feb 2019 Reputation: 100 (31-Aug-2021, 05:00 PM)the.ronin Wrote: Just trying to build up a set of data points is all. I'm coming to appreciate that so much of a frame's performance is informed by the arms. And hey, even if it is totally unusual, if it works, then it's good data. Well arm't you the clever one! as example the 5inch 5mm wideness and 2.5mm thikness does work in terms of xD it can fly in one configuration, onnthe limit about okish vibrations for cruising only. on some lightweight motors around 1306 and a lightweight 2s battery on dalprop t5051 Posts: 4,073 Threads: 75 Likes Received: 2,548 in 1,858 posts Likes Given: 3,949 Joined: May 2021 Reputation: 121 Sector25CR: 2.5” props, 8.7mm, 2.5mm Micro Alien: 3” props, 9.4mm, 2.3mm Primo3: 3” props, 5.2mm, 2.3mm Tyro119: 6” props? (I dunno, I don’t currently fly this one, but when I did it had 5”) 10.8mm, 5mm Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. |
