Throttle Control
I recently got into FPV drones and want to learn to have more control over my drone in the air, I figured I would start with learning throttle control so I am. It constantly up and down. Any tips you guys have for getting the hang of getting better at throttle control?
If you are using thumbs, you got try the pinch method.
I flew thumbs, but switched over really fast, because when I'm shaking out of fear, I'll still have more control. Smile
Don't try to increase throttle and decrease after your quad goes too high or too low. If you increase throttle, you know it'll go up too far if you keep it that way. Try compensating before it happens. Sadly I don't really know any tricks.
lots of practice... flying through air gates, or under trees... keep your altitude as low as possible...
Most people don't like it but if you can make your throttle gimble ratchet it gives your some resistance and feed back about where the throttle is moving. If you can do it there is a screw on the back of the transmitter that you adjust to make it happen.
Quads:  RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3 YouTube - Mr.E_fPv
(25-Jun-2017, 07:45 PM)rryyyaann Wrote: Most people don't like it but if you can make your throttle gimble ratchet it gives your some resistance and feed back about where the throttle is moving. If you can do it there is a screw on the back of the transmitter that you adjust to make it happen.
I have a Taranis X9D, do you know if it has this feature?
Thanks everyone for the replies so far!! Very helpful Smile
(25-Jun-2017, 07:56 PM)Spiinner Wrote: I have a Taranis X9D, do you know if it has this feature?
I believe so but its not as simple as spektrum.  You have to remove the whole back.  Check youtube for Taranis Ratchet you will see some videos.
  Left Throttle not controlling Drone soky157 7 105 23-Apr-2024, 08:21 PM
Last Post: soky157
  Death roll at 40% throttle GumbyFPV 17 395 28-Mar-2024, 03:11 PM
  Can a DJI RC Motion 2 control anything other than a DJI quad? Wellcordinated 8 600 17-Feb-2024, 05:00 PM
Last Post: segler999
  GEPRC Mark 5 - Goes full throttle unexpectedly bananagrabber61 7 574 21-Jan-2024, 12:12 AM
Last Post: bananagrabber61
  Throttle Eyes.fpv 3 231 01-Jan-2024, 01:57 AM
