Threads: 38
Likes Given: 430
118 So what exactly is the problem?
Are you unable to change vtx settings via Betaflight?
Do you get video with OSD?
Threads: 75
Likes Received: 224 in 129 posts
Likes Given: 154
5 23-Jun-2021, 02:18 AM (This post was last modified: 23-Jun-2021, 02:47 AM by BigBeard.) the issue is that the pro32 nano uses smartaudio v2.1 essentially which has to be setup in betaflight to support it. there are some guides that talk about this. Also, you have to make sure you unlock the VTX.
"Using any Smart Audio V2.1 compatible flight controller simply connect the Smart Audio data pin to a free
and supported port on your FC (see pinout below).
For Betaflight users, you can then configure the connected port in Betaflight configurator to Smart Audio
V2.1 protocol. Ideally you make sure to get a Betaflight firmware which supports the new SA2.1 (Betaflight
>=V3.5.6) rather than the older SA2.0. This way you get access to the new power levels of SA2.1."
Threads: 38
Likes Given: 430
118 Sorry, I just read you mentioned in an earlier post that you were using a Mamba F722 Basic.
I can see you are using a TBS VTX/RX mounting board. Can you test for connectivity between the SA pin on the Pro32 Nano to the SA pad on the mounting board and then also between the SA pad on the mounting board and the TX4 pas on your FC.
Threads: 38
Likes Given: 430
118 Good thing you got it sorted.
But I am surprised you have continuity but SA doesn't works while mounted on the TBS VTX/RX mounting board. Must be some sort of a electrical/RF noise issue I assume but this has never been reported previously.
