Taranis- Not working telemetry
Hi guys, im lost..
I have recently bought used Taranis 9D as upgrade from my good Turnigy 9XR. Everything was fine until I have tried to set telemetry, Taranis in not receiving anny data or discovering new sensors :/
Anny one know some solution to this situation? Is it possible to somehow fix it, or it's faulty Taranis and I should give it back?
I have two quads with naze32 (rev 5 and rev 6) with two FrSky D4R-II flashed with 28ms firmware. Everything is connected correctly with softserial 1. I have checked it many times, the problem is on Taranis side..
Im running last OpenTX version (2.1.8)
I appreciate any help  Cry
on the rev.6 you need to jump pins 5 and 6, and in the configurator make sure you have telemetry inversion on. and on the ports tab use smartport and not frsky telemetry
(18-Jul-2016, 10:52 PM)JimmyLe813 Wrote: on the rev.6 you need to jump pins 5 and 6, and in the configurator make sure you have telemetry inversion on. and on the ports tab use smartport and not frsky telemetry
Still nothing. No new sensors after hitting "discover new sensors" It's probably taranis software/hardware issue  Dodgy
(18-Jul-2016, 11:22 PM)Turtle Wrote: Still nothing. No new sensors after hitting "discover new sensors" It's probably taranis software/hardware issue  Dodgy
no need to panic bro, what makes you think it's a hardware issue? let's go through this one thing at a time could be just some little thing you're overlooking.
(19-Jul-2016, 01:46 AM)JimmyLe813 Wrote: no need to panic bro, what makes you think it's a hardware issue? let's go through this one thing at a time could be just some little thing you're overlooking.
Well, I have checked my wiring in my 2 quads multiple times, and also binded with DIY 8ch frsky mini receiver. Taranis should discover something from receivers, but nothing is showing up. The wiring was changed, the settings at CLI were changed, uploaded new firmware on receivers, new firmware on Taranis. I just can't belive that all 3 receivers are not working properly with telemetry. My conclusion is that something is messed in Taranis..but im not sure is it firmware or hardware.
I have found few similar threads and all were solved with replacing whole radio for a new one. I can't do it' because mine is from second owner :/
I have opened the radio, but nothing look's suspicious, all the traces are ok, also the wiring.
are you getting RSSI and rx voltage?
(24-Jul-2016, 12:40 AM)JimmyLe813 Wrote: are you getting RSSI and rx voltage?
same problem i am getting rx bat and rssi but not others
(15-Oct-2019, 07:20 PM)adars bhusal Wrote: same problem i am getting rx bat and rssi but not others
Please provide the following information:-
  1. Details of which flight controller and receiver you are using.
  2. Run the "dump" command in the CLI and copy/paste the results back here.
  3. Photos clearly showing the wiring between your receiver and the flight controller, including the solder connections for that wiring.
(18-Jul-2016, 11:22 PM)Turtle Wrote: Everything is connected correctly with softserial 1.
SmartPort is bidirectional and if you are using it with Softserial you have to short TX and RX pins. If you are using it with hardware UART then you can connect the SmartPort to only TX.
chupo_cro
I have the same issue with R9MM receiver. No sensors except RSSI and rxBAT.
I followed Oscar Guide (https://oscarliang.com/setup-r9m-r9-mini-betaflight/) and everything looks good (binding, betaflight sticks \ aux working) but no telemetry in the openTX except for RSSI.  I updated everyfirmware to last version.
Firmware:
Taranis Qx7: OpenTX 2.3.1
R9m & R9mm: Last firmware Flex / Flex Fport
Trasmitter Wiring:  Ground ----> Ground
          5v ---> 5v
          Inverted S.Port ---> plugged to S-Bus Receiver you can see it in the picture (UART6 RX)
[Image: sfxzLt3.jpg]
This is the DUMP from CLI
Thank you for your help
# get serialrx_provider
serialrx_provider = FPORT
Allowed values: SPEK1024, SPEK2048, SBUS, SUMD, SUMH, XB-B, XB-B-RJ01, IBUS, JETIEXBUS, CRSF, SRXL, CUSTOM, FPORT
Default value: SPEK1024
# dump
# Betaflight / OMNIBUSF4SD (OBSD) 4.0.6 Sep  1 2019 / 00:57:23 (2a64051a2) MSP API: 1.41
# start the command batch
batch start
board_name OMNIBUSF4SD
manufacturer_id
# name
name Crocodile 7
# resources
resource BEEPER 1 B04
resource MOTOR 1 B00
resource MOTOR 2 B01
resource MOTOR 3 A03
resource MOTOR 4 A02
resource MOTOR 5 A01
resource MOTOR 6 A08
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 B08
resource PWM 1 B08
resource PWM 2 B09
resource PWM 3 C06
resource PWM 4 C07
resource PWM 5 C08
resource PWM 6 C09
resource PWM 7 NONE
resource PWM 8 NONE
resource SONAR_TRIGGER 1 A01
resource SONAR_ECHO 1 A08
resource LED_STRIP 1 B06
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 NONE
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 NONE
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource INVERTER 1 NONE
resource INVERTER 2 NONE
resource INVERTER 3 C09
resource INVERTER 4 NONE
resource INVERTER 5 NONE
resource INVERTER 6 C08
resource INVERTER 7 NONE
resource INVERTER 8 NONE
resource INVERTER 9 NONE
resource INVERTER 10 NONE
resource INVERTER 11 NONE
resource INVERTER 12 NONE
resource I2C_SCL 1 NONE
resource I2C_SCL 2 NONE
resource I2C_SCL 3 NONE
resource I2C_SDA 1 NONE
resource I2C_SDA 2 NONE
resource I2C_SDA 3 NONE
resource LED 1 B05
resource LED 2 NONE
resource LED 3 NONE
resource RX_BIND 1 NONE
resource RX_BIND_PLUG 1 NONE
resource TRANSPONDER 1 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 C10
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 C11
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 C12
resource ESCSERIAL 1 B08
resource ADC_BATT 1 C02
resource ADC_RSSI 1 A00
resource ADC_CURR 1 C01
resource ADC_EXT 1 NONE
resource BARO_CS 1 B03
resource COMPASS_CS 1 NONE
resource SDCARD_CS 1 B12
resource SDCARD_DETECT 1 B07
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource FLASH_CS 1 B12
resource OSD_CS 1 A15
resource GYRO_EXTI 1 C04
resource GYRO_EXTI 2 NONE
resource GYRO_CS 1 A04
resource GYRO_CS 2 NONE
resource USB_DETECT 1 C05
# timer
timer B08 AF3
# pin B08: TIM10 CH1 (AF3)
timer B09 AF2
# pin B09: TIM4 CH4 (AF2)
timer C06 AF3
# pin C06: TIM8 CH1 (AF3)
timer C07 AF3
# pin C07: TIM8 CH2 (AF3)
timer C08 AF3
# pin C08: TIM8 CH3 (AF3)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer A03 AF1
# pin A03: TIM2 CH4 (AF1)
timer A02 AF1
# pin A02: TIM2 CH3 (AF1)
timer A01 AF2
# pin A01: TIM5 CH2 (AF2)
timer B06 AF2
# pin B06: TIM4 CH1 (AF2)
timer A08 AF1
# pin A08: TIM1 CH1 (AF1)
timer A09 AF1
# pin A09: TIM1 CH2 (AF1)
timer A10 AF1
# pin A10: TIM1 CH3 (AF1)
# dma
dma SPI_TX 1 NONE
dma SPI_TX 2 0
# SPI_TX 2: DMA1 Stream 4 Channel 0
dma SPI_TX 3 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma ADC 1 NONE
dma ADC 2 1
# ADC 2: DMA2 Stream 3 Channel 1
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin B08 NONE
dma pin B09 NONE
dma pin C06 0
# pin C06: DMA2 Stream 2 Channel 0
dma pin C07 0
# pin C07: DMA2 Stream 2 Channel 0
dma pin C08 0
dma pin C09 0
dma pin B00 0
dma pin B01 0
dma pin A03 1
# pin A03: DMA1 Stream 6 Channel 3
dma pin A02 0
# pin A02: DMA1 Stream 1 Channel 3
dma pin A01 0
# pin A01: DMA1 Stream 4 Channel 6
dma pin B06 0
dma pin A08 0
dma pin A09 0
dma pin A10 0
# mixer
mixer QUADX
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mix
smix reset
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature -DYNAMIC_FILTER
feature RX_SERIAL
feature TELEMETRY
feature LED_STRIP
feature OSD
feature ANTI_GRAVITY
feature DYNAMIC_FILTER
# beeper
beeper -GYRO_CALIBRATED
beeper -RX_LOST
beeper -RX_LOST_LANDING
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper ARMING_GPS_NO_FIX
beeper -BAT_CRIT_LOW
beeper -BAT_LOW
beeper -GPS_STATUS
beeper -RX_SET
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
beeper MULTI_BEEPS
beeper -DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -BLACKBOX_ERASE
beeper -CRASH_FLIP
beeper -CAM_CONNECTION_OPEN
beeper -CAM_CONNECTION_CLOSE
beeper -RC_SMOOTHING_INIT_FAIL
# beacon
beacon -RX_LOST
beacon -RX_SET
# map
map TAER1234
serial 0 2 115200 57600 0 115200
serial 2 8192 115200 57600 0 115200
serial 5 64 115200 57600 0 115200
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1700 2100 0 0
aux 1 1 1 900 1300 0 0
aux 2 2 0 1300 1700 0 0
aux 3 13 2 1300 2100 0 0
aux 4 28 3 1300 1700 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtx
vtx 0 0 0 0 900 900
vtx 1 0 0 0 900 900
vtx 2 0 0 0 900 900
vtx 3 0 0 0 900 900
vtx 4 0 0 0 900 900
vtx 5 0 0 0 900 900
vtx 6 0 0 0 900 900
vtx 7 0 0 0 900 900
vtx 8 0 0 0 900 900
vtx 9 0 0 0 900 900
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# display_name
display_name -
# master
set gyro_sync_denom = 1
set gyro_lowpass_type = BIQUAD
set gyro_lowpass_hz = 150
set gyro_lowpass2_type = PT1
set gyro_lowpass2_hz = 150
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = ON
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_notch_range = AUTO
set dyn_notch_q = 120
set dyn_notch_min_hz = 150
set dyn_lpf_gyro_min_hz = 150
set dyn_lpf_gyro_max_hz = 450
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_roll = 0
set acc_calibration = 72,22,-6
set align_mag = DEFAULT
set mag_bustype = I2C
set mag_i2c_device = 2
set mag_i2c_address = 0
set mag_spi_device = 0
set mag_hardware = NONE
set mag_declination = 0
set mag_calibration = 0,0,0
set baro_bustype = SPI
set baro_spi_device = 3
set baro_i2c_device = 0
set baro_i2c_address = 0
set baro_hardware = AUTO
set baro_tab_size = 21
set baro_noise_lpf = 600
set baro_cf_vel = 985
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 200
set rssi_offset = 0
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RPYT
set rc_interp_int = 19
set rc_smoothing_input_hz = 0
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = FPORT
set serialrx_inverted = OFF
set spektrum_sat_bind = 0
set serialrx_halfduplex = OFF
set adc_device = 2
set blackbox_p_ratio = 32
set blackbox_device = SDCARD
set blackbox_record_acc = ON
set blackbox_mode = NORMAL
set min_throttle = 1050
set max_throttle = 2000
set dshot_idle_value = 450
set dshot_burst = ON
set dshot_bidir = OFF
set use_unsynced_pwm = OFF
set motor_pwm_protocol = DSHOT1200
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 4
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set align_board_yaw = 0
set gimbal_mode = NORMAL
set bat_capacity = 0
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_lpf_period = 30
set ibat_lpf_period = 10
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 400
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = OFF
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set small_angle = 180
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_rescue_angle = 32
set gps_rescue_yaw_p = 40
set gps_rescue_throttle_min = 1200
set gps_rescue_min_sats = 8
set gps_rescue_min_dth = 100
set gps_rescue_use_mag = ON
set deadband = 0
set yaw_deadband = 0
set pid_process_denom = 1
set thrust_linear = 0
set transient_throttle_limit = 15
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
set sdcard_detect_inverted = ON
set sdcard_mode = SPI
set sdcard_dma = OFF
set sdcard_spi_bus = 2
set osd_units = METRIC
set osd_warn_crash_flip = ON
set osd_warn_esc_fail = ON
set osd_warn_core_temp = ON
set osd_warn_fail_safe = ON
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_alt_alarm = 120
set osd_esc_temp_alarm = -128
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_vbat_pos = 234
set osd_rssi_pos = 6276
set osd_tim_1_pos = 234
set osd_tim_2_pos = 6550
set osd_flymode_pos = 6530
set osd_g_force_pos = 234
set osd_throttle_pos = 6541
set osd_vtx_channel_pos = 234
set osd_crosshairs_pos = 205
set osd_ah_sbar_pos = 10478
set osd_ah_pos = 10350
set osd_current_pos = 234
set osd_mah_drawn_pos = 6242
set osd_motor_diag_pos = 234
set osd_craft_name_pos = 234
set osd_gps_speed_pos = 2199
set osd_gps_lon_pos = 234
set osd_gps_lat_pos = 234
set osd_gps_sats_pos = 2125
set osd_home_dir_pos = 2158
set osd_home_dist_pos = 234
set osd_flight_dist_pos = 6230
set osd_compass_bar_pos = 234
set osd_altitude_pos = 6262
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_warnings_pos = 329
set osd_avg_cell_voltage_pos = 14402
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_nvario_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_flip_arrow_pos = 234
set osd_core_temp_pos = 234
set osd_log_status_pos = 234
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = ON
set osd_stat_max_spd = ON
set osd_stat_max_dist = OFF
set osd_stat_min_batt = ON
set osd_stat_endbatt = OFF
set osd_stat_battery = OFF
set osd_stat_min_rssi = ON
set osd_stat_max_curr = ON
set osd_stat_used_mah = ON
set osd_stat_max_alt = ON
set osd_stat_bbox = ON
set osd_stat_bb_no = ON
set osd_stat_flight_dist = ON
set osd_stat_max_fft = OFF
set osd_profile = 1
set system_hse_mhz = 8
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set scheduler_optimize_rate = OFF
set vtx_band = 4
set vtx_channel = 1
set vtx_power = 1
set vtx_freq = 5740
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vcd_video_system = AUTO
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = DEFAULT
set max7456_spi_bus = 3
set max7456_preinit_opu = OFF
set led_inversion = 0
set dashboard_i2c_bus = 2
set dashboard_i2c_addr = 60
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set flash_spi_bus = 2
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_2_bustype = SPI
set gyro_2_spibus = 1
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_2_sensor_align = DEFAULT
set gyro_rpm_notch_q = 500
set gyro_rpm_notch_min = 100
set dterm_rpm_notch_q = 500
set dterm_rpm_notch_min = 100
set rpm_notch_lpf = 150
# profile
profile 2
set dyn_lpf_dterm_min_hz = 150
set dyn_lpf_dterm_max_hz = 250
set dterm_lowpass_type = BIQUAD
set dterm_lowpass_hz = 150
set dterm_lowpass2_type = PT1
set dterm_lowpass2_hz = 100
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_gain = 5000
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = OFF
set smart_feedforward = OFF
set iterm_relax = RP
set iterm_relax_cutoff = 20
set iterm_windup = 100
set iterm_limit = 400
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 0
set throttle_boost = 5
set acro_trainer_gain = 75
set p_pitch = 46
set i_pitch = 70
set d_pitch = 38
set f_pitch = 75
set p_roll = 42
set i_roll = 60
set d_roll = 35
set f_roll = 70
set p_yaw = 35
set i_yaw = 100
set d_yaw = 0
set f_yaw = 0
set angle_level_strength = 50
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set d_min_roll = 20
set d_min_pitch = 22
set d_min_yaw = 0
set d_min_boost_gain = 27
set d_min_advance = 20
set motor_output_limit = 100
set launch_angle_limit = 0
set launch_control_gain = 40
# rateprofile
set thr_mid = 50
set thr_expo = 0
set rates_type = BETAFLIGHT
set roll_rc_rate = 100
set pitch_rc_rate = 100
set yaw_rc_rate = 100
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 50
set tpa_breakpoint = 1500
set tpa_mode = D
set throttle_limit_type = OFF
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
# end the command batch
batch end
(20-Oct-2019, 04:25 AM)Enrico79 Wrote: I have the same issue with R9MM receiver. No sensors except RSSI and rxBAT.
Your first issue is that FPORT only works over a bi-directional TX UART connection so the R9MM won't get telemetry data back on the SBUS connection (which is an RX connection, and on the F4 boards it is also inverted). It looks like that FC only has 3 hardware UARTs and you are already using UART 1 for GPS and UART 3 for Tramp. I therefore suggest you move the wire from the the SBUS pin to the T6 pad.
You will also need to run the following command in the CLI...
set serialrx_halfduplex = ON
save
(20-Oct-2019, 08:52 AM)SnowLeopardFPV Wrote: Your first issue is that FPORT only works over a bi-directional TX UART connection so the R9MM won't get telemetry data back on the SBUS connection (which is an RX connection, and on the F4 boards it is also inverted). It looks like that FC only has 3 hardware UARTs and you are already using UART 1 for GPS and UART 3 for Tramp. I therefore suggest you move the wire from the the SBUS pin to the T6 pad.
save
Mate, first of all thank you so much for your help. Smile
This is the actual situation on my FC.
As far as i understand, you suggest to remove the signal white wire from the plugged pin and to solder it on the T6 pad? am i right?  Can i leave ground and voltage plugged there?
Thank you!
[Image: iqhxky2.jpg]
Hey mate.
first of all thanks so much, it worked and now i got telemetry working from fc to TX.
Nonetheless i lost SmartAudio. It was working on uart 3 set as IRC Tramp peripherical. Now it doesn't. Any idea how to fix? sorry i'm so noob.
(20-Oct-2019, 02:03 PM)Enrico79 Wrote: Mate, first of all thank you so much for your help. Smile
Correct. Move the white wire to the T6 pad. The red and black wires can remain in the plug.
You might want to consider running a completely new wire from the Inverted S.Port pad on the R9MM to the T6 pad on the FC rather than just cutting the white wire from the plug and moving it. Then you can just remove the white wire pin from the plug complete with the wire. That just leaves things a bit neater without cut off wires hanging out of plugs. It's up to you.
Don't forget to also run that CLI command.
#15
(20-Oct-2019, 04:36 PM)Enrico79 Wrote: Hey mate.
Looks like we cross posted with each other Big Grin Sorry I didn't reply sooner as I was away from my computer doing other real life stuff Smile
So you are now getting both stick movement in Betaflight AND telemetry back to your Taranis, yes? And the white wire from the plug is now soldered to the T6 pad, yes?
Can you please post another CLI dump so I can double check your current serial settings now that you made some changes.
  tango 2 no telemetry screens cele_FPV 6 93 Yesterday, 10:48 PM
  Crossfire diversity wrong telemetry data noize 15 1,772 22-Mar-2024, 06:21 AM
Last Post: Myman
  Help Crossfire not working on flight controller? relentlesstech 8 237 02-Mar-2024, 05:48 PM
Last Post: relentlesstech
  BetaFPV Elrs module not loading in a taranis X7 Stumpy 2 208 31-Jan-2024, 12:19 PM
Last Post: Stumpy
  betafpv elrs micro rx pwm not working PJKMBAKER 9 398 22-Dec-2023, 09:34 PM
Last Post: PJKMBAKER
