15-Jan-2021, 12:19 AM
Hoping someone here offer advice on getting my GEPRC Phantom HD BNF to fly well on 4S batteries. I’ve had multiple flyaway situations with this drone on stock BF4.1 firmware both on 450mah or 650mah batteries, and the issues seem to apply to both copies of the drone I currently own. I’ve dumped hours into trying to fix this because when the drone seems to fly well, it is almost too good to be true - fast, quiet for parks, great battery life, and feels so fun in the air due to its super low weight. I don't have 3S batteries the right size, and furthermore have heard the quad is a little underpowered on 3S anyway.
The big pain I can’t stop is the constant flyaways. I’ll arm the quad, take off, and the throttle will feel super light and floaty, almost like antigravity is turned way up.. Then I'll few turns (or worst, a bump or even just a leaf passing over the motor) and suddenly the quad is 30-40 feet in the air and I’m hitting disarm and praying that it crashes into the grass.
Everything hardware about these quads are stock except that at some point in troubleshooting I dropped in some of that Ummagawd sticky stuff to help prevent battery ejections during crashes.
Quad ships with BF4.1, and recommended batteries are 3-4S, 300-450mah. However, [DutchRC Adventures] reported on his youtube channel that he has heard many reports of flyaways on 4S. His fix was to bump down master mix to 0.9, and move the filtering sliders to “less filtering” 1.4 each. With those settings, I was able to get a floaty but stable 4S at 450mah, but immediate flyaways on 650mah. And even on 450mah there is a jitter I can hear on the motors.
My current (probably broken) understanding of the problem is that there is some measured vibration on the quad that is passing through the filters, causing a "dterm windup". This problem presents on both of my copies (including my second one which has had zero hard crashes and the props are entirely new.)
Things I’ve tried:
* Reseting to completely default tune in BF4.17, BF4.2 - no change
* Disabling anti-gravity - sometimes helps a little with landing the quad but still flyaways occur
* Fuddling around with normal quad tuning regime (start with clean PIDs and low filtering, then slowly build up P to bracket vibrations, etc.) No good, flys away even on lower PID gains settings
* Applying URUAV’s community settings for toothpicks. Helped a little bit on 350mah, but still immediate flyaway on 650mah
* Default sliders on PIDs, but lower PD balance to 0.9, and back down on stick gain to 0.9. Raised Gyro and Dterm multiplier to 1.8. Added RPM filtering and JESC. This last one now flies really well on 450 but with immediate flyaway on 650mah.
The most recent settings are actually quite promising but I don’t fully trust them. For one, why does REDUCING the filtering help? Wouldn’t we want MORE filtering if the problem is vibrations? Secondly, the fact that even the small increase in weight from 450->650 causes problems, which tells me the tune is not very robust.
Can someone wiser than I advise on what might be happening here? What the most likely scenario is the root issue? Is this d-term windup? Can the quad even be made to run on 650mah? Why wouldn’t it?
BTW: Geprc support was completely useless. They claim their quad works perfectly on 4S at 450mah, and I have video evidence from a new in box quad on 4S 450mah that this is absolutely not true. They were very terse in their responses. I'm starting to think its not a great company to buy from.
Attachments: Stock BF config, Config with the DutchRC adventures, and the most recent config that sort of works but I don't trust.
Things I’ve tried:
