T-Motor F4 Flight Controller installation
Hi..
I am gonna install this FC
previously i always use the AIO (without PDB / 4in1 esc)
please forgive me for my dumb questions  Smile
[Image: 93522247-fe27-4f55-a7e3-6dadd7b9687e.jpg]
Since i am using individual esc... then i will need PDB
and i will use MATEK PDB Lipo 3-4S
[Image: e17fa903-1d55-40c1-8e6b-73dfce1ec88c.jpg]
the question is :
- how do i give power from pdb to FC, which pad do i need to solder from pdb to FC ? ( i am using 4S battery)
- i will install used motor, and the signal wire is not long enough, will it effect performance if i solder extension
- and also will it effect performance if i solder extension to motor cable
please suggest... Thank you
Can I connect power like this ?
use small cable ?
I need battery voltage reading from FC OSD
Yes. But probably easier to use grd and VCC in PDB. Soldering two wires on a single pad is harder. Regardless, it is the same thing.
oh... i just noticed that
VCC and GND beside the Lipo pad hole
thanks for the advice
At last..
Not very neat ?
[Image: 20190903-221505.jpg]
[-] The following 1 user Likes w3njember's post:
  • RENOV8R
Not too bad. Twisting wires helps keep them neater. Example, your wires running to the camera.
I am using TBS Crossfire nano , and wired RX TX to FC as instructed
i can connect my jumperT16 to quad,
I check the receiver, and set modes,
can change VTX channel via OSD
I got battery voltage in OSD
but RSSI in OSD stuck at 49
any wiring or betaflight setup that is wrong ?
[Image: Capture.png]
[Image: 20190904-112517.jpg]
[Image: 20190904-111809.jpg]
Solved...
I set chan 8 for RSSI
In betaflight i also set RSSI channel 8
Should be 4
  JHEMCU GHF745 HD AIO F7 OSD Flight Controller and Built-In 40A BLHeli32 3-6S FC husafreak 14 290 10-May-2024, 03:12 PM
Last Post: husafreak
  Semi Newbie here - T-Motor F7 Pro Full Function Tonestire 9 1,479 19-Feb-2024, 07:23 AM
Last Post: MontyFPV
  Help No response flight controller with receiver Crazyart 1 266 09-Jan-2024, 12:53 AM
Last Post: Crazyart
  BetaFPV F4 FR 2S flight controller issues. itsmerandy 30 1,801 02-Nov-2023, 09:01 AM
Photo Help Mamba F405 Motor 3 not working when LED added Toppers 20 3,634 01-Nov-2023, 10:21 PM
Last Post: onesimos
