Swapped ESC
I had to swap an ESC due to it exploding I couldn't get the same one so got one as similar as possible. When I plug the battery in the motors twitch as they should but it only makes half of the startup beep sequence it should and no leds light up on the lux fc. Any ideas? Do I need to reset something in beta flight, not sure if it will even connect as I don't have a computer to hand.
Thank you very much for any ideas.
Make sure you flash with the same version firmware and calibrate the ESCs again.
You will need a computer to do this.
Thanks voodoo Im not sure how to do this "b heli suite"? 3x dys xms30A 1x favorite little bee 30A
Flash with blheli suite or chrome extension.
ESCs calibration in betaflight configurator. Or in blheli suite.
I have never ran different ESCs, but I can't see why it wouldn't work. You might have to flash the little bee separately.
You should bought the same esc, they sell the DYS xsm 20a.
If you don't get the low/high beeps after the three beep startup tone, then the ESCs are not seeing a throttle signal from the flight controller.
If you don't get any LEDs on the flight controller lighting up then I'd say that the ESC that blew up also took the flight controller with it.
  • RENOV8R
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 268 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 119 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Solved Cannot connect ESC derange 2 147 22-Mar-2024, 10:05 PM
Last Post: derange
  Solved Cannot recognise 1 Esc at 4in 1 Esc Mad35 11 217 12-Mar-2024, 01:47 PM
  Help ESC working but motor not spinning Prashant1901 1 146 10-Mar-2024, 02:09 AM
