25-Nov-2023, 05:50 AM
Facing a new problem. Need help.
My config on the problem quad is:
frame: OpenRacer with 5mm fatty arms
FC: SkyStarsRC F722 Mini HD Pro 20x20
ESC: REDUX32 PRO F4 70A 128KHZ 20X20
motors: iFlight XING2 2207 1855kv
GPS: Matek m10q 5883
receiver: Radiomaster RP1
At the end of a recent race, I crashed my quad and it fried a motor. So I replaced the motor and it ran fine again. But a few days after that, the motors have started running fast out of the blue for 3-5 sec periods at random times, while not moving the throttle, causing the quad to fly up and shake. These short 3-5 sec episodes are getting more and more frequent.
I started to troubleshoot.
- I checked all the motors and even upgraded to BLHeli32 v32.10. Problem persists.
- I replaced the ESC. Problem persists.
- I replaced the FC. Problem persists.
- I reflashed Betaflight to the new 4.4.3 version. Problem persists.
- I disabled the GPS. Problem persists.
- I checked all cables. Problem persists.
- I disabled AirMode, which help a bit but I hate flying without it and it's not addressing the root cause of the problem.
- I put the OpenRacer0 O3 canopy (+ VTX/cam/ant) on my Vista OpenRacer2 frame (+ ESC/FC/motors/GPS) and everything ran flawlessly. This means the O3 unit and the Boxer controller are not the source of the problem.
- I checked the frame and it is OK.
- I recorded the phenomenon on the BlackBox 3 times during a 50sec flight. I am attaching the tracings.
Josh Bardwell thinks the gyro is damaged or something else is damaged causing bad gyro readings, which causes the PID loop to freak out. But the problem persists after replacing the FC.
Any idea where to go next?
I have just bought 4 new motors, a new FC and a new ESC and a new RP1, that I will install when received next week. Rebuilding the quad from scratch should solve the problem. But I'd like to know where the problem is exactly.
Benoit
Benoit
