Hello,
In Betaflight receiver tab, I got all switches and pots working fine (So I guess all inputs and mixes setup correctly in taranis)
The issue is, after I run set usb_hid_cdc = on in betaflight and check Game controller properties in windows, I don't see movement in windows for all the switches/pots.
Throttle/Yaw, Rolle/Pitch, SD and SC works.
SA, SB, SE and the pot has no movements in windows.
Any idea how to get this fixed?
If I directly connect the taranis using usb cable, I got everything works.
Thanks.
Thanks.
