Solid Strand Wires for FPV gear?
Will using solid strand wire(as opposed to multistrand traditionally used) to power the vtx and camera cause a any issues? The kind of wite used in the telecommunications industry? I have some and it is capable of a tight twist to prevent outside power influence.
As far as I know the only downside is flexibility, but it may be more susceptible to interference.
Twisted pairs for signal is good. Twisting the dc lines won't have any effect except possibly damping noise a smidge.
Solid core is brittle, don't use it.
Solid strand wire is more susceptible to fatigue breakage from vibrations. It also has lower ampacity compared to similar gauge stranded wire.
[-] The following 1 user Likes Charpu5's post:
  • Jordan Marinov
  News FAA Endgame: No recreational FPV flying outside of a FRIA? SnowLeopardFPV 26 1,215 19-Mar-2024, 11:33 PM
  Hobby wing for fpv is like plant based “meat” is to a cow Rob Axel 3 163 06-Feb-2024, 11:58 PM
  FPV article / Talk with Lexie Janson Cyfly 0 220 21-Oct-2023, 11:24 AM
Last Post: Cyfly
  AI drone beats Pro FPV pilots FPVme 4 304 24-Sep-2023, 10:18 PM
Last Post: BadComputer
  Carrying FPV Gear for Quick Guerrilla Flights. FPVme 10 499 19-Aug-2023, 02:55 AM
Last Post: FPVme
