SBUS/Telem on Naze32 with FrSky x8r Questions
I've read a quite a bit on this topic and I have a few questions, mainly from Oscar's blog entry here http://blog.oscarliang.net/sbus-smartpor...ry-naze32/
It seems that mainly this "hack" usually involves the naze32 rev5 with the X4r receiver or the naze32 rev6 with the X8r receiver.  I have the naze32 rev5 board with an X8r.  Am I wasting my time or will this same process work?
If all it takes is connecting SBUS out to pins ground, power, and pin 4 on the naze32, then what is the purpose or benefit of making an inverter cable.  Is that so you can using pin 1 on the naze32 instead of pin 4?
And then I'm pretty squared away with the smart port being the same on the x8r as it is on the x4r, and that signal wire will go to both pins 5&6 on the FC.
I bought the taranis with the x8r and I will get the d4r receiver if I have to but it would be nice to make it work with what I have.
Thanks.
So any discussion on this topic?
as long as you are using the inverter cable, both RX should work with both Naze32 rev5 or rev6.
because the SBUS signal from Frsky RX are inverted, that's why you need an inverter. F3 flight controllers have built-in inverter so that cable isn't needed.
  Help Speedybee F7 V3 connection questions Griffin Ucos 4 669 07-Dec-2023, 05:41 PM
Last Post: Griffin Ucos
  Help crux35 crazyf411 frsky failsafes after ~1min robbfox11 0 153 28-Jul-2023, 02:56 AM
Last Post: robbfox11
  SpeedyBee F7V3 SBUS VBasic thrust 0 370 21-Jun-2023, 05:57 PM
Last Post: thrust
  Spektrum SPM4650 questions my sanity masahl 3 533 08-Jun-2023, 09:21 PM
Last Post: Skavage
  Mamba F722 Mini Mk 3 no SBUS pad. Peterev 2 530 16-Sep-2022, 01:12 AM
Last Post: Peterev
