02-Sep-2019, 12:56 PM
So I installed a MATEK F411-WING with iNAV into my S800.
I have passthrough (manual), acro and angle mode on a switch on my TX.
In passthrough / manual mode everything works OK and I can do a roll without issue.
Then I switch to acro mode and I see in the OSD than the mode is indeed changed from MAN to AIR.
Now in this mode I noticed that a roll is much slower.
If searched a lot but I haven't found the correct setting to make it quicker.
I quess it's a 'rate' setting somewhere.
Does anyone know which setting(s) I should look at?
Thanks.
Thanks.
