Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 01-Jan-2021, 04:52 AM (This post was last modified: 01-Jan-2021, 05:35 AM by the.ronin.) I've come across yet another odd behavior from a Runcam camera. Since the Runcam Hybrid, my sense has been quality at Runcam has really gone downhill with random issues popping up everywhere. In this case, my Runcam Split 4 (the single board, whoop size 1080p 60FPS cam) seems to conflict with something preventing my RapidFire to get a signal lock. The kicker is that if I power off / disconnect the Runcam, I *immediately* get signal lock. I have tried all of the following with zero success: * Recalibrated the RapidFire and also made sure it had the latest firmware. * Testing 2 other quads one of which uses the same Matek Mini VTX used with the problematic Runcam Split 4 and on each one, I get an *immediate* signal lock. * Tried powering the Runcam Split 4 off direct 3S lipo. * Tried phsycally separating the Split 4 and the Matek VTX on the bench. * Tried switching to PAL. I am beside myself as to why this is happening. I really need this signal lock since this is supposed to be a micro long range (the Diatone Roma build). I'll tell ya I am pissed at Runcam. Their shit just seems to keep f*cking breaking. • Posts: 359 Threads: 14 Likes Received: 163 in 126 posts Likes Given: 1 Joined: Jul 2020 Reputation: 12 That's weird. Does anything showing up on the spectrum analyzer or just not getting a clean video signal when you power on the goggles? Tried disconnect the vtx and see if there's some funky rf being sent out from the runcam stomping on your vtx. • Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 Video is perfectly clean. But I am hesitant to go out much further than the 500m or so without that signal lock. Already tried physically separating the VTX from the Runcam PCB on the bench - same issue. Also made sure I was using the right VTX trable for the Matek Mini. Short of it is, I am using that Matek Mini VTX on another build where I am having zero issues. This Matek Mini specifically was used on a previous build with a Caddx Tarsier with zero issues. I really just think Runcam has gone to shit. • Posts: 21,307 Threads: 589 Likes Received: 8,988 in 6,653 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 789 Have you tried the legacy mode on the RapidFIRE module (assuming that mode still exists in the latest firmware versions)? That will put you back into old school diversity mode which doesn't require a sync lock. TBH, I would probably trust diversity more than the RapidFIRE modes for doing long range flights with. • Posts: 8 Threads: 3 Likes Received: 1 in 1 posts Likes Given: 0 Joined: Jan 2021 Reputation: 0 Lol, just posted something similar. I just bought my rapidfire module together with the Runcam split 4 and I have the same issue. Just found out now, that if no signal bars on the osd, no signal lock. I have the exact same issue. • Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 Thats a good point Snow. I'd still like to get the RSSI bars working if anything since this likely is a symptom of a bigger issue that could lead to a critical failure midflight. End of the day, Runcam needs to pull its head out of its ass. • Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 01-Jan-2021, 08:09 PM (This post was last modified: 01-Jan-2021, 09:09 PM by the.ronin.) Ok for anyone having this issue, I think it may be a power related issue. I had tried to power the Split 4 off lipo earlier but still had the problem of the RapidFire not locking. I am later going to try and power the Split 4 off a 9v BEC rather than straight off a 5v pad on the FC and will report back. Scratch that. Just tried powering off 9v BEC still issue. Also tried powering off of the Matek VTX 5V and G pads still issue. Here is the oddity ... when I hook the Split 4 up to my camera testing rig which is just a RDQ Mach 3 VTX, I am getting signal lock with the RapidFire. I cannot figure out what the difference in the setup is. I have already tried bypassing the FC power distribution altogether by powering direct off lipo as well as with a BEC off lipo. I am not having any issues with the Matek on my Gecko. And when I tried hooking up the Split 4 to the Gecko build with the Matek, same issue with no signal lock. I just don't freeging get it. • Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 Ok just tried replacing the Matek VTX with a TBS Pro. Same issue. • Posts: 8 Threads: 3 Likes Received: 1 in 1 posts Likes Given: 0 Joined: Jan 2021 Reputation: 0 i have the exact same problem with the TBS Unify32 Nano v1.1, I have two of them. I get a signal lock with both of them on the Caddx Ratel but no signal lock with the runcam split 4 Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 Like you were suggesting to me, Stat, it's an issue with the Split 4. Runcam just needed to get their new product of the week out as quickly as possible and decided quality testing was for chumps, evidently. • Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 I am seriously beginning to suspect a FPV industry-wide memo was sent out something to the effect of, "Watch out for this ronin guy. He likes bringing the manufacturers to task and calling out their crap quality control. If he reaches out to you, ask stupid questions and he will eventually get bored and move on." ... cos this is the response I got from ImmersionRC when I showed them the video ... ImmersionRC Repairs Wrote:Hi, I am a little confused, in your video how do you have a video image when the camera (split 4) is not powered on? Regards, Dave So I'm actually, really hoping that memo is real because if this is the tech guy behind the gadget I use to send $$$$$ of gear out to the great wide, yonder, we are all direly effed. • Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 Shoot I totally forgot to share this video. Runcam kept bugging me with questions so I made this for them and posted it public. • Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 06-Jan-2021, 09:28 AM (This post was last modified: 06-Jan-2021, 09:44 AM by the.ronin.) Hilarity ... These morons have there heads stuck so far up their woohoo it's not even funny anymore. Gonna avoid these idiots like covid. Posts: 4,550 Threads: 38 Likes Received: 1,245 in 1,064 posts Likes Given: 430 Joined: Aug 2020 Reputation: 118 (06-Jan-2021, 09:28 AM)the.ronin Wrote: Hilarity ... These morons have there heads stuck so far up their woohoo it's not even funny anymore. Gonna avoid these idiots like covid. I thought the newer Runcam’s had firmware updates? So something like this can’t be fixed by a firmware update? Strange to me unless its really a hardware issue. They probably won’t offer you a refund I assume. • Posts: 220 Threads: 33 Likes Received: 99 in 68 posts Likes Given: 38 Joined: Aug 2020 Reputation: 2 I have the same issue with split 3 and Eachine EV300O/SKY04X. The problem is "fixed" moving from mix to diversity mode. Anyway, funny answer you got. Andrea - "If you want to check your quad durability, let me fly (crash) it" • |
