18-Oct-2020, 01:18 PM
I've been eyeing off this frame for a while and finally pulled the trigger on the purchase.
http://rebelminiquads.com/free-range-ruxus-customizer/
Here's where I ended up....
And now onto the build
SPECS:
The Ruxus is a strong frame, the arms are 10mm thick, it's crazy.
The frame came in a nice box for once and the parts are all top notch carbon. The TPU prints are epic. Thank you American manufacturing .
Look at these arms, the 10mm is pure balls. An armattan rooster 5 inch arm is in front for comparison. At only three motor mount holes I'm thinking I need to purchase some locktite finally.
The centre plate where the stack is mounted (both 20mm and 30mm stacks OK) is minimal and takes advantage of a double stack arrangement that holds the arms in place. The two gear shaped inserts milled out of the carbon fibre in the picture below hold nuts in place that in turn hold two bolts to keep the arms locked in position. Needless to say getting it all together was a bit tricky. In my wisdom I decided to wire up the arms first and solder the ESC. Doing that first made it tricky to mount it all together AND tighten these two darn bolts...
Sometimes if the heatshrink will fit, I like to pre-build the arms and get all the components in place. In this case the FC I'm using for this build supports 4 RGB LED strips so I've put an RGB led strip in in arm.
After a fair bit of fussing about I got it all together and mounted the arms to the main plates. I also soldered up the motor wires to the 4in1 esc and mounted the esc as well. Starting to look pretty sweet!
This is where I really like the ZeeZ setup, there are locations on this FC to direct solder (via a pin header) a crossfire nano RX and unify nano VTX. It was pretty straight forward to do and ends up looking very neat. I placed some double sided foam tape under the RX and VTX to keep it off the FC. There is no flex in the solder joins but it helps against any shorts or stresses.
The FC went on in a pretty straight forward and unimaginative manner, big builds make me lazy, lol..
Time to do a quick check and power it all up. Here I am testing the RGB LEDS, VTX, RX, etc... The little USB fan is great to have handy. I've got the LEDs in the knight rider scanning mode for now, it's cool, lol... Why the hell not I reakon.
More to come..
SPECS:
- Rebel Ruxus free range 7 inch frame
- BrotherHobby Avenger V3 2306.5 2000Kv motors
- ZeeZ F7 FC and 60A 4in1 BLHeli32 ESC
- Crossfire Nano RX with immortal-T antenna, vertically polarized mount.
- Crossfire Unify Nano VTX with TrueRC OCP U.FL antenna.
More to come..
