READY TO FLY
Well after a lot of hair pulling and some GREAT help from a bunch of you.....She's ready for flight...    I need some BEGINNERS help here!!!!
what are the best " INPUT'" and " MIXER " setting are good to start with for a rookie flying his first racer ????? i did download "LIFT-OFF" and have been practicing a lot on the Simulator.... Settings on my Simulator setting in my Qx7 are 50 and 50 for input and mixer..... [Image: tsL93AOl.jpg][Image: n4iLZ6sl.jpg]
[-] The following 2 users Like JD Quad Jammer's post:
  • kaitylynn, unseen
Personally, I kept everything at 100%. If you can fly the simulator, you will be able to fly the real thing. For your first flight, find yourself a large open field. When you lift off, don't baby it. Keep your craft high and make your turns. Landing is always the hard part. You don't have to land close to you. Just concentrate on putting the craft down gently. Good luck. Break an arm. Ha...
  • unseen
Looks great
I havent touched mixer settings on mine yet . Just waiting for some good weather to get some real air time in.
Really just done motor calibration, POV and switch setup in betaflight.
I have drone racing league sim but not sure I like it. Just buying liftoff
Can agree with what's above. Mixer is not really needed yet. As mentioned before, get some air, and work on your turning and banking. Make sure to have some visual landmarks so you can judge not only where you are pointing, but how your turning is going as well. I would also say do not land close to you. Not at least until you are a little better at it. Landing can get squirrely sometimes and it is not good to be close. I would recommend testing the failsafe switch a few times prior to taking off, just to verify. It takes some getting used to, but it is easy to get addicted, lol
PS. Is that electrical tape around your stack?
(03-Jan-2018, 09:56 PM)voodoo614 Wrote: Personally, I kept everything at 100%.  If you can fly the simulator, you will be able to fly the real thing.  For your first flight, find yourself a large open field.  When you lift off, don't baby it. Keep your craft high and make your turns. Landing is always the hard part.  You don't have to land close to you.  Just concentrate on putting the craft down gently. Good luck.  Break an arm. Ha...
thats just it VooDoo.  just per a video setup i did.  i made a model in my qx7 just for the sim.. and it had me move the settings to 50 and 50..... should i move them back up ??  and how much (to the real thang ) is the Sim LIFTOFF ? cuz with higher setting GOOD GOD ... is it sensative.... should i go back up ?
(04-Jan-2018, 12:08 AM)s3npai Wrote: Can agree with what's above. Mixer is not really needed yet. As mentioned before, get some air, and work on your turning and banking. Make sure to have some visual landmarks so you can judge not only where you are pointing, but how your turning is going as well. I would also say do not land close to you. Not at least until you are a little better at it. Landing can get squirrely sometimes and it is not good to be close. I would recommend testing the failsafe switch a few times prior to taking off, just to verify. It takes some getting used to, but it is easy to get addicted, lol
yes thats elec tape ..   temporary tho.. my telemetry and receiver wires are plugged in.. will eventually solder them....just dont want them to vibrate out...
and QUESTION about the inputs!!!!  what does the MIXER do in relation to the INPUTS ?????
(03-Jan-2018, 10:30 PM)Droning Martyn Wrote: Looks great
THANKS.....
i dont know where you live... but im in Illinois by St louis.. and its RATS ASS cold here... plus i haven't even got my FATSHARK goggles yet..  i have a FORCE1 and HOLYSTONE drone i play with in my back yard when i can..... but mostly its been sim time on LIFTOFF......
(04-Jan-2018, 12:30 AM)JD Quad Jammer Wrote: thats just it VooDoo.  just per a video setup i did.  i made a model in my qx7 just for the sim.. and it had me move the settings to 50 and 50..... should i move them back up ??  and how much (to the real thang ) is the Sim LIFTOFF ? cuz with higher setting GOOD GOD ... is it sensative.... should i go back up ?
It is hard to judge which way you will learn better. My friend who is just starting took my advice. Left TX at 100%, hit the simulator hard. His first ever real flight, he flown my 5in quads on 4S and did great. No crashes. Did a bunch of power loops. Even went under some trees. You can decrease your rates if things are too sensitive and increase them when you get better.
(04-Jan-2018, 02:35 AM):thumbsup:voodoo614 Wrote: It is hard to judge which way you will learn better. My friend who is just starting took my advice. Left TX at 100%, hit the simulator hard. His first ever real flight, he flown my 5in quads on 4S and did great. No crashes. Did a bunch of power loops. Even went under some trees. You can decrease your rates if things are too sensitive and increase them when you get better.
Thumbs Up
  Do You fly on acro mode with cinewoop for indoor ? Seanalami 12 5,757 6 hours ago
Last Post: Flybyjim
  fly in summer Eyes.fpv 14 336 13-Apr-2024, 09:27 PM
Last Post: husafreak
  Camera View on DJI Fly for non-DJI drone fwpsam 2 202 01-Apr-2024, 05:43 PM
Last Post: fwpsam
  cant fly FPV after 5 months HELP PLZZZ jayzor08 9 323 08-Jan-2024, 01:31 PM
Last Post: iFly4rotors
Thumbs Up I am ready to give up at this point... (SOLVED) Seii-FPV 6 1,156 12-Sep-2023, 04:11 PM
Last Post: Seii-FPV
