Threads: 46
Likes Received: 152 in 88 posts
Likes Given: 61
11 Hello to all
I will be purchasing a new pc this fall which of course will probably come with windows 11
My question is this. Is windows 11 usually working with Betaflight, Inav, EdgeTx, etc?
Or should I wait a little longer for everything to mesh together?
Thanks
Roger74
IF YOU BUILD IT, IT WILL CRASH
Threads: 589
Likes Received: 8,984 in 6,649 posts
Likes Given: 1,426
789 All of the FPV related software we use works perfectly fine under Windows 11 and I've not yet found anything that doesn't work.
Threads: 71
Likes Received: 340 in 254 posts
Likes Given: 157
19 The only issue I have had was with STM Electronics Virtual Com Port drivers needed for some FCs. The Driver Fixers out there didn't work.
STM do not do a Win 11 or even a Win 10 version, and the Win8 version in the readme says do not use on Win 10 (11 was not out when it was written)
The answer I was advised was to use the Win7 version and ignore the "not for this version" warning. That worked.
Threads: 46
Likes Given: 61
11 (14-Aug-2023, 03:41 PM)roger74 Wrote: Hello to all
Thanks
Roger74
Ok well that gives me some assurance that this should not be a hassle when the new PC gets up and running.
Thank you to everyone who helped
