Quadcopter build: motors dont spin
Hello I followed a video on YouTube by UAVfutures features. I got an all in 4 esc with an f3 fc.
I got a turnigy evolution receiver which contain an ai6c reciever. I got everything finished and binded. When it came time to check i gave it a bit of throttle and nothing. When I hooked it up to clean flight. Under the reciever tab non of the bars move as I throttle or yaw, nothing! My controller is binded. When plug the battery in, the motors move slightly.
Thanks in advance i really want to get my quadcopter up in the air & thanks in advance for my beginner question.
BTW when I connect my quad two lights come on ( one steady blue & a blinking red light)
I don't know if English is your first language or not, but there is no such word as "binded". The past tense of "to bind" is "bound".
If you don't see any movement in the receiver tab, check that you have connected the receiver to the flight controller correctly. Check that you have set the correct receiver configuration.
If you think you have checked all this, show us how you have connected things and how you have set things up in the configurator.
Also something that may help Omar,
Which receiver are you using? The one I use needs certain pins to be jumpered when binding or it'll appear like everything is fine but not do anything when wired up to the quad.
carl.vegas
Make sure you have the correct receiver type defined on your Configuration tab.
I'm using PWM (One wire per channel) and this is not the default, so I spent some time to figure out what was happening.
Have a look on this, once you fix this and you see the bars moving at receiver tab, then test the motors (motors tab first) and ENSURE you don't have the propellers installed.
Hope it helps
(22-Apr-2017, 12:48 PM)Carl.Vegas Wrote: Also something that may help Omar,
I'm using the turnigy ia6c reciever. I set it up with ibus/sbus
(23-Apr-2017, 01:27 AM)flabombarda Wrote: Make sure you have the correct receiver type defined on your Configuration tab.
Hope it helps
So I did check the motors and they are working. My only problem is that in cleanflight my radio is not recognized. I have done what you suggested, but on my computer when I try to click default it doesn't allow me too. I'm only allowed 2 different options only
(23-Apr-2017, 07:16 PM)Omar90221 Wrote: So I did check the motors and they are working. My only problem is that in cleanflight my radio is not recognized. I have done what you suggested, but on my computer when I try to click default it doesn't allow me too. I'm only allowed 2 different options only
Omar, I´m sorry but I don´t understand.
You say here that motors dont spin and cleanflight doesn´t recognize it, so how do you know this is actually working fine ?
Please clarify so we try to help you because if your motors dont´t spin and and receiver is not recognized I don´t why you think it´s working, looks like a piece is missing in this puzzle  Confused
Thanks
(23-Apr-2017, 07:43 PM)flabombarda Wrote: Omar, I´m sorry but I don´t understand.
Thanks
On cleanflight , under the motor tab I checked the motors to see if everything was wired right and working. When I went to test them, they were spining and working. So my only problem now is that on cleanflight my radio isn't bieng recognized. Under the reciever tab, none of the bars move as I throttle up or yaw, spin.. nothing moves. Hope this is clear enough
Omar,
What Radio you are using, what kind of connection to the FC you have and what is your current Receiver mode at Configuration tab on cleanflight ?
If you power the quad with battery, and go to the motors tab, are motors spinning ? Keep in mind that just by plugging USB will not power your motors, you need the battery properly plugged also.
so for now:
- you have proven that motors + esc + FC are wired correctly and you can spin them up in the motor tab.
next things to validate:
- connection between FC and RX, (have you soldered the parts to the right place? do you need to make any bridge with solder (ibus/ppm? on your FC))
- if there is power in the RX
- it it is bound correctly with your TX
- if it (RX) is configured to output ibus/sbus?
- if you are using ibus / sbus have you configured CORRECT port as serial RX ?
- if you are using ibus / sbus have you configured the CORRECT mode in the config tab (serial/ibus/sbus etc)
- if all above an in rx tab you see the movement which is not aligned to your tx play with the mapping in the combobox... AERT typically works for those radios.
most likley places that you might have missed something are - Wrong uart configured as serial_RX ( i do this all the time)
also ... pictures will help us understand better your connections (FC + RX)
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
Here are some pictures, hope they help, I'm trying to upload the wiring of the quad but it's unable too so once I can I will upload it
Here's the quad set up wiring,
(23-Apr-2017, 08:45 PM)flabombarda Wrote: Omar,
Yes they motors do spin, when the battery is connected. I have a turnigy evolution radio with an ai6c reciever
(24-Apr-2017, 07:38 PM)Omar90221 Wrote: Here are some pictures, hope they help, I'm trying  to upload the wiring of the quad but it's unable too so once I can I will upload it
If the black red and white wires going off the picture to the lower right are for your receiver, it is connected to UART3, not UART2 as you have it set in the configurator. Try setting only UART3 as a serial receiver instead.
edit: You can find the manual for the original board at seriouslypro.com
This is the web site of Dominic Clifton, who designed the SeriouslyPro F3 flight controller and more. He's also the driving force behind Cleanflight. You can also buy some of his latest flight controllers directly at his shop and support him, Cleanflight and the hobby in general.
  • Carl.Vegas, RENOV8R
(24-Apr-2017, 10:21 PM)unseen Wrote: If the black red and white wires going off the picture to the lower right are for your receiver, it is connected to UART3, not UART2 as you have it set in the configurator. Try setting only UART3 as a serial receiver instead.
thanks, that was the whole problem. I set the serial reciever and right away it picked up the radios movements !
[-] The following 2 users Like Omar90221's post:
  • unseen, Carl.Vegas
  Very inconsistent motors/ARMING tenaciousFPV 7 130 Today, 04:11 AM
Last Post: husafreak
  Why do higher voltage batteries need lower KV motors? Eyes.fpv 1 119 04-May-2024, 01:42 AM
  Recommended 3.5 build for a newbie mintjberry 16 410 03-May-2024, 10:15 PM
Last Post: mintjberry
  Motors not responding to transmitter input(no airmode) corwin 1 91 22-Apr-2024, 05:07 PM
  Beta95x V3 motors not start kronk 3 125 20-Apr-2024, 07:28 PM
Last Post: kronk
