17-Mar-2021, 11:35 AM
Hi guys, I'm here with a stupid question today.
I would like to ask you if it's a good idea to store my quads with propellers mounted and tightened nuts.
I've seen many videos on youtube of walls covered by hundreds of hanged quads and all of them were hanged with propellers mounted. Is it a good idea to keep propellers on ? Tightened nuts may cause any damage over time ? Is it better to leave the propellers on with loose nuts? (Obviously, if needed, I will completely remove them before running the motors on the bench!)
In addition, please look at the following picture
Propellers have been tightened with approximately the same torque and, if you look at the nut of the front-right motor, the shaft is clearly protruding from the nut more than the other. Why ? Is it possible that the shaft is longer ? Damaged nylon gasket inside the nut ? Anything else?
Thank you!
Thank you!
