Posts: 46 Threads: 18 Likes Received: 1 in 1 posts Likes Given: 0 Joined: Sep 2020 Reputation: 0 FPV community, so I recently upgraded my tinyhawk 2 freestyle with tx30 pigs tail, switching out old motor and added range. I noticed the mapping of the motor was incorrect so I thought I was correcting it by using CLI. I believe mapped incorrectly can someone help with the mapping iisue • Posts: 21,263 Threads: 587 Likes Received: 8,969 in 6,637 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 788 Are you still using the standard Tinyhawk 2 FC in your quad? There is no need to remap anything if you simply just switched out a motor for another one. Can you please run both the "dump" and "diff all" commands in the Betaflight Configurator CLI tab and copy/paste the results back here. • Posts: 46 Threads: 18 Likes Received: 1 in 1 posts Likes Given: 0 Joined: Sep 2020 Reputation: 0 Excuse me If I am green, asking questions that I understand I’m still very new to this and appreciate your help: your request # diff ###WARNING: NO CUSTOM DEFAULTS FOUND### # version # Betaflight / STM32F411 (S411) 4.1.0 Oct 16 2019 / 11:57:34 (c37a7c91a) MSP API: 1.42 # manufacturer_id: MTKS board_name: MATEKF411RX custom defaults: NO # start the command batch batch start board_name MATEKF411RX manufacturer_id MTKS # name: TH II Freestyle # resources resource BEEPER 1 C15 resource MOTOR 1 B00 resource MOTOR 2 B10 resource MOTOR 3 B08 resource MOTOR 4 B06 resource PPM 1 A03 resource PWM 1 A02 resource PWM 2 A09 resource PWM 3 A10 resource LED_STRIP 1 A00 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 A02 resource SERIAL_RX 1 A10 resource SERIAL_RX 2 A03 resource LED 1 C13 resource SPI_SCK 1 A05 resource SPI_SCK 2 B13 resource SPI_SCK 3 B03 resource SPI_MISO 1 A06 resource SPI_MISO 2 B14 resource SPI_MISO 3 B04 resource SPI_MOSI 1 A07 resource SPI_MOSI 2 B15 resource SPI_MOSI 3 B05 resource ADC_BATT 1 B00 resource ADC_CURR 1 B01 resource OSD_CS 1 B12 resource RX_SPI_CS 1 A15 resource RX_SPI_EXTI 1 C14 resource RX_SPI_BIND 1 B02 resource RX_SPI_LED 1 B09 resource RX_SPI_CC2500_TX_EN 1 A08 resource RX_SPI_CC2500_LNA_EN 1 A13 resource RX_SPI_CC2500_ANT_SEL 1 A14 resource GYRO_EXTI 1 A01 resource GYRO_CS 1 A04 # timer timer A03 AF3 # pin A03: TIM9 CH2 (AF3) timer B10 AF1 # pin B10: TIM2 CH3 (AF1) timer B06 AF2 # pin B06: TIM4 CH1 (AF2) timer B07 AF2 # pin B07: TIM4 CH2 (AF2) timer B08 AF2 # pin B08: TIM4 CH3 (AF2) timer A00 AF2 # pin A00: TIM5 CH1 (AF2) timer A02 AF3 # pin A02: TIM9 CH1 (AF3) timer A09 AF1 # pin A09: TIM1 CH2 (AF1) timer A10 AF1 # pin A10: TIM1 CH3 (AF1) # dma dma ADC 1 0 # ADC 1: DMA2 Stream 0 Channel 0 dma pin B10 0 # pin B10: DMA1 Stream 1 Channel 3 dma pin B06 0 # pin B06: DMA1 Stream 0 Channel 2 dma pin B07 0 # pin B07: DMA1 Stream 3 Channel 2 dma pin B08 0 # pin B08: DMA1 Stream 7 Channel 2 dma pin A00 0 # pin A00: DMA1 Stream 2 Channel 6 dma pin A09 0 # pin A09: DMA2 Stream 6 Channel 0 dma pin A10 0 # pin A10: DMA2 Stream 6 Channel 0 # feature feature -RX_PARALLEL_PWM feature RX_SERIAL feature TELEMETRY feature OSD # beeper beeper -CAM_CONNECTION_CLOSE beeper -RC_SMOOTHING_INIT_FAIL # map map TAER1234 # serial serial 0 64 115200 57600 0 115200 serial 1 2048 115200 57600 0 115200 # aux aux 0 0 0 1525 2075 0 0 aux 1 1 1 1300 1700 0 0 aux 2 1 0 900 900 0 2 aux 3 2 1 1800 2100 0 0 aux 4 13 2 900 1375 0 0 # vtxtable vtxtable bands 5 vtxtable channels 8 vtxtable band 1 BOSCAM_A A FACTORY 5865 5845 5825 5805 5785 5765 5745 5725 vtxtable band 2 BOSCAM_B B FACTORY 5733 5752 5771 5790 5809 5828 5847 5866 vtxtable band 3 BOSCAM_E E FACTORY 5705 5685 5665 0 5885 5905 0 0 vtxtable band 4 FATSHARK F FACTORY 5740 5760 5780 5800 5820 5840 5860 5880 vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable powerlevels 3 vtxtable powervalues 0 1 2 vtxtable powerlabels 25 100 200 # master set gyro_lowpass2_hz = 325 set dyn_lpf_gyro_min_hz = 260 set dyn_lpf_gyro_max_hz = 650 set acc_calibration = -195,-77,55 set mag_hardware = NONE set baro_hardware = NONE set max_check = 2000 set rssi_offset = 20 set serialrx_provider = CRSF set serialrx_inverted = ON set rx_spi_protocol = FRSKY_X set rx_spi_bus = 3 set rx_spi_led_inversion = ON set min_throttle = 1070 set dshot_idle_value = 250 set dshot_burst = AUTO set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT600 set motor_pwm_rate = 480 set motor_poles = 12 set vbat_max_cell_voltage = 440 set vbat_min_cell_voltage = 320 set vbat_warning_cell_voltage = 330 set current_meter = NONE set battery_meter = ADC set ibata_scale = 179 set beeper_inversion = ON set beeper_od = OFF set small_angle = 180 set deadband = 1 set yaw_deadband = 1 set pid_process_denom = 1 set osd_warn_batt_not_full = OFF set osd_warn_visual_beeper = OFF set osd_warn_core_temp = OFF set osd_warn_rc_smoothing = OFF set osd_warn_no_gps_rescue = OFF set osd_warn_gps_rescue_disabled = OFF set osd_warn_rssi = ON set osd_cap_alarm = 450 set osd_vbat_pos = 2159 set osd_rssi_pos = 396 set osd_tim_2_pos = 2392 set osd_flymode_pos = 65 set osd_vtx_channel_pos = 2402 set osd_craft_name_pos = 2088 set osd_display_name_pos = 394 set osd_pid_roll_pos = 353 set osd_pid_pitch_pos = 34 set osd_pidrate_profile_pos = 186 set osd_warnings_pos = 297 set osd_avg_cell_voltage_pos = 2167 set osd_flip_arrow_pos = 310 set osd_rate_profile_name_pos = 23 set osd_pid_profile_name_pos = 2 set osd_stat_max_spd = OFF set osd_stat_battery = ON set osd_stat_max_curr = OFF set osd_stat_used_mah = OFF set osd_stat_bbox = OFF set osd_stat_bb_no = OFF set osd_stat_total_time = ON set system_hse_mhz = 8 set vtx_band = 5 set vtx_channel = 4 set vtx_low_power_disarm = UNTIL_FIRST_ARM set vtx_freq = 5769 set vcd_video_system = NTSC set max7456_spi_bus = 2 set frsky_spi_tx_id = 42,177 set frsky_spi_offset = -46 set frsky_spi_bind_hop_data = 6,229,219,209,199,189,179,169,159,149,139,129,119,109,99,89,79,69,59,49,39,29,19,9,234,224,214,204,194,184,174,164,154,144,136,124,114,104,94,84,74,64,54,44,34,24,14,255,255,255 set cc2500_spi_chip_detect = OFF set gyro_1_bustype = SPI set gyro_1_spibus = 1 set gyro_1_sensor_align = CW270 set gyro_1_align_yaw = 2700 set gyro_2_spibus = 1 set name = TH II Freestyle profile 0 # profile 0 set dyn_lpf_dterm_min_hz = 0 set dyn_lpf_dterm_max_hz = 250 set dterm_lowpass_hz = 100 set dterm_lowpass2_hz = 200 set feedforward_transition = 25 set acc_limit_yaw = 100 set iterm_rotation = ON set iterm_relax = RPY set iterm_relax_type = GYRO set iterm_relax_cutoff = 11 set iterm_windup = 40 set iterm_limit = 150 set throttle_boost = 4 set d_pitch = 32 set d_roll = 30 set angle_level_strength = 60 set horizon_level_strength = 30 set horizon_transition = 80 set level_limit = 30 set d_min_roll = 0 set d_min_pitch = 0 set auto_profile_cell_count = 2 set ff_boost = 13 rateprofile 0 # rateprofile 0 set thr_mid = 25 set thr_expo = 50 set roll_rc_rate = 65 set pitch_rc_rate = 65 set yaw_rc_rate = 80 set roll_expo = 65 set pitch_expo = 65 set yaw_expo = 20 set yaw_srate = 60 set tpa_rate = 25 set tpa_breakpoint = 1650 set throttle_limit_type = SCALE set throttle_limit_percent = 75 # end the command batch batch end # • Posts: 46 Threads: 18 Likes Received: 1 in 1 posts Likes Given: 0 Joined: Sep 2020 Reputation: 0 # dump ###WARNING: NO CUSTOM DEFAULTS FOUND### # version # Betaflight / STM32F411 (S411) 4.1.0 Oct 16 2019 / 11:57:34 (c37a7c91a) MSP API: 1.42 # manufacturer_id: MTKS board_name: MATEKF411RX custom defaults: NO # start the command batch batch start board_name MATEKF411RX manufacturer_id MTKS # name: TH II Freestyle # resources resource BEEPER 1 C15 resource MOTOR 1 B00 resource MOTOR 2 B10 resource MOTOR 3 B08 resource MOTOR 4 B06 resource MOTOR 5 NONE resource MOTOR 6 NONE resource MOTOR 7 NONE resource MOTOR 8 NONE resource SERVO 1 NONE resource SERVO 2 NONE resource SERVO 3 NONE resource SERVO 4 NONE resource SERVO 5 NONE resource SERVO 6 NONE resource SERVO 7 NONE resource SERVO 8 NONE resource PPM 1 A03 resource PWM 1 A02 resource PWM 2 A09 resource PWM 3 A10 resource PWM 4 NONE resource PWM 5 NONE resource PWM 6 NONE resource PWM 7 NONE resource PWM 8 NONE resource SONAR_TRIGGER 1 NONE resource SONAR_ECHO 1 NONE resource LED_STRIP 1 A00 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 A02 resource SERIAL_TX 3 NONE resource SERIAL_TX 4 NONE resource SERIAL_TX 5 NONE resource SERIAL_TX 6 NONE resource SERIAL_TX 7 NONE resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_TX 12 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 A03 resource SERIAL_RX 3 NONE resource SERIAL_RX 4 NONE resource SERIAL_RX 5 NONE resource SERIAL_RX 6 NONE resource SERIAL_RX 7 NONE resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE resource SERIAL_RX 12 NONE resource INVERTER 1 NONE resource INVERTER 2 NONE resource INVERTER 3 NONE resource INVERTER 4 NONE resource INVERTER 5 NONE resource INVERTER 6 NONE resource INVERTER 7 NONE resource INVERTER 8 NONE resource INVERTER 9 NONE resource INVERTER 10 NONE resource INVERTER 11 NONE resource INVERTER 12 NONE resource I2C_SCL 1 NONE resource I2C_SCL 2 NONE resource I2C_SCL 3 NONE resource I2C_SDA 1 NONE resource I2C_SDA 2 NONE resource I2C_SDA 3 NONE resource LED 1 C13 resource LED 2 NONE resource LED 3 NONE resource RX_BIND 1 NONE resource RX_BIND_PLUG 1 NONE resource TRANSPONDER 1 NONE resource SPI_SCK 1 A05 resource SPI_SCK 2 B13 resource SPI_SCK 3 B03 resource SPI_MISO 1 A06 resource SPI_MISO 2 B14 resource SPI_MISO 3 B04 resource SPI_MOSI 1 A07 resource SPI_MOSI 2 B15 resource SPI_MOSI 3 B05 resource ESCSERIAL 1 NONE resource CAMERA_CONTROL 1 NONE resource ADC_BATT 1 B00 resource ADC_RSSI 1 NONE resource ADC_CURR 1 B01 resource ADC_EXT 1 NONE resource BARO_CS 1 NONE resource BARO_EOC 1 NONE resource BARO_XCLR 1 NONE resource COMPASS_CS 1 NONE resource COMPASS_EXTI 1 NONE resource SDCARD_CS 1 NONE resource SDCARD_DETECT 1 NONE resource PINIO 1 NONE resource PINIO 2 NONE resource PINIO 3 NONE resource PINIO 4 NONE resource USB_MSC_PIN 1 NONE resource FLASH_CS 1 NONE resource OSD_CS 1 B12 resource RX_SPI_CS 1 A15 resource RX_SPI_EXTI 1 C14 resource RX_SPI_BIND 1 B02 resource RX_SPI_LED 1 B09 resource RX_SPI_CC2500_TX_EN 1 A08 resource RX_SPI_CC2500_LNA_EN 1 A13 resource RX_SPI_CC2500_ANT_SEL 1 A14 resource GYRO_EXTI 1 A01 resource GYRO_EXTI 2 NONE resource GYRO_CS 1 A04 resource GYRO_CS 2 NONE resource USB_DETECT 1 NONE resource VTX_POWER 1 NONE resource VTX_CS 1 NONE resource VTX_DATA 1 NONE resource VTX_CLK 1 NONE resource PULLUP 1 NONE resource PULLUP 2 NONE resource PULLUP 3 NONE resource PULLUP 4 NONE resource PULLDOWN 1 NONE resource PULLDOWN 2 NONE resource PULLDOWN 3 NONE resource PULLDOWN 4 NONE # timer timer A03 AF3 # pin A03: TIM9 CH2 (AF3) timer B10 AF1 # pin B10: TIM2 CH3 (AF1) timer B06 AF2 # pin B06: TIM4 CH1 (AF2) timer B07 AF2 # pin B07: TIM4 CH2 (AF2) timer B08 AF2 # pin B08: TIM4 CH3 (AF2) timer A00 AF2 # pin A00: TIM5 CH1 (AF2) timer A02 AF3 # pin A02: TIM9 CH1 (AF3) timer A09 AF1 # pin A09: TIM1 CH2 (AF1) timer A10 AF1 # pin A10: TIM1 CH3 (AF1) # dma dma SPI_TX 1 NONE dma SPI_TX 2 NONE dma SPI_TX 3 NONE dma SPI_RX 1 NONE dma SPI_RX 2 NONE dma SPI_RX 3 NONE dma ADC 1 0 # ADC 1: DMA2 Stream 0 Channel 0 dma ADC 2 NONE dma ADC 3 NONE dma UART_TX 1 NONE dma UART_TX 2 NONE dma UART_TX 3 NONE dma UART_TX 4 NONE dma UART_TX 5 NONE dma UART_TX 6 NONE dma UART_TX 7 NONE dma UART_TX 8 NONE dma UART_RX 1 NONE dma UART_RX 2 NONE dma UART_RX 3 NONE dma UART_RX 4 NONE dma UART_RX 5 NONE dma UART_RX 6 NONE dma UART_RX 7 NONE dma UART_RX 8 NONE dma pin A03 NONE dma pin B10 0 # pin B10: DMA1 Stream 1 Channel 3 dma pin B06 0 # pin B06: DMA1 Stream 0 Channel 2 dma pin B07 0 # pin B07: DMA1 Stream 3 Channel 2 dma pin B08 0 # pin B08: DMA1 Stream 7 Channel 2 dma pin A00 0 # pin A00: DMA1 Stream 2 Channel 6 dma pin A02 NONE dma pin A09 0 # pin A09: DMA2 Stream 6 Channel 0 dma pin A10 0 # pin A10: DMA2 Stream 6 Channel 0 # mixer mixer QUADX mmix reset # servo servo 0 1000 2000 1500 100 -1 servo 1 1000 2000 1500 100 -1 servo 2 1000 2000 1500 100 -1 servo 3 1000 2000 1500 100 -1 servo 4 1000 2000 1500 100 -1 servo 5 1000 2000 1500 100 -1 servo 6 1000 2000 1500 100 -1 servo 7 1000 2000 1500 100 -1 # servo mixer smix reset # feature feature -RX_PPM feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -RANGEFINDER feature -TELEMETRY feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -OSD feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -RX_SPI feature -SOFTSPI feature -ESC_SENSOR feature -ANTI_GRAVITY feature -DYNAMIC_FILTER feature RX_SERIAL feature TELEMETRY feature OSD feature AIRMODE feature ANTI_GRAVITY feature DYNAMIC_FILTER # beeper beeper GYRO_CALIBRATED beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper ARMING_GPS_NO_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACC_CALIBRATION beeper ACC_CALIBRATION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper ARMED beeper SYSTEM_INIT beeper ON_USB beeper BLACKBOX_ERASE beeper CRASH_FLIP beeper CAM_CONNECTION_OPEN beeper -CAM_CONNECTION_CLOSE beeper -RC_SMOOTHING_INIT_FAIL # beacon beacon -RX_LOST beacon -RX_SET # map map TAER1234 # serial serial 20 1 115200 57600 0 115200 serial 0 64 115200 57600 0 115200 serial 1 2048 115200 57600 0 115200 # led led 0 0,0::C:0 led 1 0,0::C:0 led 2 0,0::C:0 led 3 0,0::C:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 # color color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 # mode_color mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 0 mode_color 5 1 0 mode_color 5 2 0 mode_color 5 3 0 mode_color 5 4 0 mode_color 5 5 0 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 mode_color 7 0 3 # aux aux 0 0 0 1525 2075 0 0 aux 1 1 1 1300 1700 0 0 aux 2 1 0 900 900 0 2 aux 3 2 1 1800 2100 0 0 aux 4 13 2 900 1375 0 0 aux 5 0 0 900 900 0 0 aux 6 0 0 900 900 0 0 aux 7 0 0 900 900 0 0 aux 8 0 0 900 900 0 0 aux 9 0 0 900 900 0 0 aux 10 0 0 900 900 0 0 aux 11 0 0 900 900 0 0 aux 12 0 0 900 900 0 0 aux 13 0 0 900 900 0 0 aux 14 0 0 900 900 0 0 aux 15 0 0 900 900 0 0 aux 16 0 0 900 900 0 0 aux 17 0 0 900 900 0 0 aux 18 0 0 900 900 0 0 aux 19 0 0 900 900 0 0 # adjrange adjrange 0 0 0 900 900 0 0 0 0 adjrange 1 0 0 900 900 0 0 0 0 adjrange 2 0 0 900 900 0 0 0 0 adjrange 3 0 0 900 900 0 0 0 0 adjrange 4 0 0 900 900 0 0 0 0 adjrange 5 0 0 900 900 0 0 0 0 adjrange 6 0 0 900 900 0 0 0 0 adjrange 7 0 0 900 900 0 0 0 0 adjrange 8 0 0 900 900 0 0 0 0 adjrange 9 0 0 900 900 0 0 0 0 adjrange 10 0 0 900 900 0 0 0 0 adjrange 11 0 0 900 900 0 0 0 0 adjrange 12 0 0 900 900 0 0 0 0 adjrange 13 0 0 900 900 0 0 0 0 adjrange 14 0 0 900 900 0 0 0 0 adjrange 15 0 0 900 900 0 0 0 0 adjrange 16 0 0 900 900 0 0 0 0 adjrange 17 0 0 900 900 0 0 0 0 adjrange 18 0 0 900 900 0 0 0 0 adjrange 19 0 0 900 900 0 0 0 0 adjrange 20 0 0 900 900 0 0 0 0 adjrange 21 0 0 900 900 0 0 0 0 adjrange 22 0 0 900 900 0 0 0 0 adjrange 23 0 0 900 900 0 0 0 0 adjrange 24 0 0 900 900 0 0 0 0 adjrange 25 0 0 900 900 0 0 0 0 adjrange 26 0 0 900 900 0 0 0 0 adjrange 27 0 0 900 900 0 0 0 0 adjrange 28 0 0 900 900 0 0 0 0 adjrange 29 0 0 900 900 0 0 0 0 # rxrange rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 # vtx vtx 0 0 0 0 0 900 900 vtx 1 0 0 0 0 900 900 vtx 2 0 0 0 0 900 900 vtx 3 0 0 0 0 900 900 vtx 4 0 0 0 0 900 900 vtx 5 0 0 0 0 900 900 vtx 6 0 0 0 0 900 900 vtx 7 0 0 0 0 900 900 vtx 8 0 0 0 0 900 900 vtx 9 0 0 0 0 900 900 # vtxtable vtxtable bands 5 vtxtable channels 8 vtxtable band 1 BOSCAM_A A FACTORY 5865 5845 5825 5805 5785 5765 5745 5725 vtxtable band 2 BOSCAM_B B FACTORY 5733 5752 5771 5790 5809 5828 5847 5866 vtxtable band 3 BOSCAM_E E FACTORY 5705 5685 5665 0 5885 5905 0 0 vtxtable band 4 FATSHARK F FACTORY 5740 5760 5780 5800 5820 5840 5860 5880 vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable powerlevels 3 vtxtable powervalues 0 1 2 vtxtable powerlabels 25 100 200 # rxfail rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h # master set gyro_hardware_lpf = NORMAL set gyro_sync_denom = 1 set gyro_lowpass_type = PT1 set gyro_lowpass_hz = 200 set gyro_lowpass2_type = PT1 set gyro_lowpass2_hz = 325 set gyro_notch1_hz = 0 set gyro_notch1_cutoff = 0 set gyro_notch2_hz = 0 set gyro_notch2_cutoff = 0 set gyro_calib_duration = 125 set gyro_calib_noise_limit = 48 set gyro_offset_yaw = 0 set gyro_overflow_detect = ALL set yaw_spin_recovery = ON set yaw_spin_threshold = 1950 set gyro_to_use = FIRST set dyn_notch_range = MEDIUM set dyn_notch_width_percent = 8 set dyn_notch_q = 120 set dyn_notch_min_hz = 150 set dyn_lpf_gyro_min_hz = 260 set dyn_lpf_gyro_max_hz = 650 set gyro_filter_debug_axis = ROLL set acc_hardware = AUTO set acc_lpf_hz = 10 set acc_trim_pitch = 0 set acc_trim_roll = 0 set acc_calibration = -195,-77,55 set align_mag = DEFAULT set mag_align_roll = 0 set mag_align_pitch = 0 set mag_align_yaw = 0 set mag_bustype = SPI set mag_i2c_device = 0 set mag_i2c_address = 0 set mag_spi_device = 0 set mag_hardware = NONE set mag_declination = 0 set mag_calibration = 0,0,0 set baro_bustype = SPI set baro_spi_device = 0 set baro_i2c_device = 0 set baro_i2c_address = 0 set baro_hardware = NONE set baro_tab_size = 21 set baro_noise_lpf = 600 set baro_cf_vel = 985 set mid_rc = 1500 set min_check = 1050 set max_check = 2000 set rssi_channel = 0 set rssi_src_frame_errors = OFF set rssi_scale = 100 set rssi_offset = 20 set rssi_invert = OFF set rssi_src_frame_lpf_period = 30 set rc_interp = AUTO set rc_interp_ch = RPYT set rc_interp_int = 19 set rc_smoothing_type = FILTER set rc_smoothing_input_hz = 0 set rc_smoothing_derivative_hz = 0 set rc_smoothing_debug_axis = ROLL set rc_smoothing_input_type = BIQUAD set rc_smoothing_derivative_type = BIQUAD set rc_smoothing_auto_smoothness = 10 set fpv_mix_degrees = 0 set max_aux_channels = 14 set serialrx_provider = CRSF set serialrx_inverted = ON set spektrum_sat_bind = 0 set spektrum_sat_bind_autoreset = ON set srxl2_unit_id = 1 set srxl2_baud_fast = ON set sbus_baud_fast = OFF set airmode_start_throttle_percent = 25 set rx_min_usec = 885 set rx_max_usec = 2115 set serialrx_halfduplex = OFF set rx_spi_protocol = FRSKY_X set rx_spi_bus = 3 set rx_spi_led_inversion = ON set adc_device = 1 set adc_vrefint_calibration = 0 set adc_tempsensor_calibration30 = 0 set adc_tempsensor_calibration110 = 0 set input_filtering_mode = OFF set blackbox_p_ratio = 32 set blackbox_device = SERIAL set blackbox_record_acc = ON set blackbox_mode = NORMAL set min_throttle = 1070 set max_throttle = 2000 set min_command = 1000 set dshot_idle_value = 250 set dshot_burst = AUTO set dshot_bidir = OFF set dshot_bitbang = AUTO set dshot_bitbang_timer = AUTO set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT600 set motor_pwm_rate = 480 set motor_pwm_inversion = OFF set motor_poles = 12 set thr_corr_value = 0 set thr_corr_angle = 800 set failsafe_delay = 4 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_switch_mode = STAGE1 set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set failsafe_recovery_delay = 20 set failsafe_stick_threshold = 30 set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 0 set gimbal_mode = NORMAL set bat_capacity = 0 set vbat_max_cell_voltage = 440 set vbat_full_cell_voltage = 410 set vbat_min_cell_voltage = 320 set vbat_warning_cell_voltage = 330 set vbat_hysteresis = 1 set current_meter = NONE set battery_meter = ADC set vbat_detect_cell_voltage = 300 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set vbat_cutoff_percent = 100 set force_battery_cell_count = 0 set vbat_lpf_period = 30 set ibat_lpf_period = 10 set vbat_duration_for_warning = 0 set vbat_duration_for_critical = 0 set vbat_scale = 110 set vbat_divider = 10 set vbat_multiplier = 1 set ibata_scale = 179 set ibata_offset = 0 set ibatv_scale = 0 set ibatv_offset = 0 set beeper_inversion = ON set beeper_od = OFF set beeper_frequency = 0 set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = OFF set crashflip_motor_percent = 0 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set 3d_limit_low = 1000 set 3d_limit_high = 2000 set 3d_switched_mode = OFF set servo_center_pulse = 1500 set servo_pwm_rate = 50 set servo_lowpass_hz = 0 set tri_unarmed_servo = ON set channel_forwarding_start = 4 set reboot_character = 82 set serial_update_rate_hz = 100 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set small_angle = 180 set auto_disarm_delay = 5 set gyro_cal_on_first_arm = OFF set gps_provider = NMEA set gps_sbas_mode = AUTO set gps_auto_config = ON set gps_auto_baud = OFF set gps_ublox_use_galileo = OFF set gps_set_home_point_once = OFF set gps_use_3d_speed = OFF set gps_rescue_angle = 32 set gps_rescue_initial_alt = 50 set gps_rescue_descent_dist = 200 set gps_rescue_landing_alt = 5 set gps_rescue_landing_dist = 10 set gps_rescue_ground_speed = 2000 set gps_rescue_throttle_p = 150 set gps_rescue_throttle_i = 20 set gps_rescue_throttle_d = 50 set gps_rescue_velocity_p = 80 set gps_rescue_velocity_i = 20 set gps_rescue_velocity_d = 15 set gps_rescue_yaw_p = 40 set gps_rescue_throttle_min = 1100 set gps_rescue_throttle_max = 1600 set gps_rescue_ascend_rate = 500 set gps_rescue_descend_rate = 150 set gps_rescue_throttle_hover = 1280 set gps_rescue_sanity_checks = RESCUE_SANITY_ON set gps_rescue_min_sats = 8 set gps_rescue_min_dth = 100 set gps_rescue_allow_arming_without_fix = OFF set gps_rescue_alt_mode = MAX_ALT set gps_rescue_use_mag = ON set deadband = 1 set yaw_deadband = 1 set yaw_control_reversed = OFF set pid_process_denom = 1 set runaway_takeoff_prevention = ON set runaway_takeoff_deactivate_delay = 500 set runaway_takeoff_deactivate_throttle_percent = 20 set thrust_linear = 0 set transient_throttle_limit = 0 set tlm_inverted = OFF set tlm_halfduplex = ON set frsky_default_lat = 0 set frsky_default_long = 0 set frsky_gps_format = 0 set frsky_unit = IMPERIAL set frsky_vfas_precision = 0 set hott_alarm_int = 5 set pid_in_tlm = OFF set report_cell_voltage = OFF set ibus_sensor = 1,2,3,0,0,0,0,0,0,0,0,0,0,0,0 set mavlink_mah_as_heading_divisor = 0 set telemetry_disabled_voltage = OFF set telemetry_disabled_current = OFF set telemetry_disabled_fuel = OFF set telemetry_disabled_mode = OFF set telemetry_disabled_acc_x = OFF set telemetry_disabled_acc_y = OFF set telemetry_disabled_acc_z = OFF set telemetry_disabled_pitch = OFF set telemetry_disabled_roll = OFF set telemetry_disabled_heading = OFF set telemetry_disabled_altitude = OFF set telemetry_disabled_vario = OFF set telemetry_disabled_lat_long = OFF set telemetry_disabled_ground_speed = OFF set telemetry_disabled_distance = OFF set telemetry_disabled_esc_current = ON set telemetry_disabled_esc_voltage = ON set telemetry_disabled_esc_rpm = ON set telemetry_disabled_esc_temperature = ON set telemetry_disabled_temperature = OFF set ledstrip_visual_beeper = OFF set ledstrip_visual_beeper_color = WHITE set ledstrip_grb_rgb = GRB set ledstrip_profile = STATUS set ledstrip_race_color = ORANGE set ledstrip_beacon_color = WHITE set ledstrip_beacon_period_ms = 500 set ledstrip_beacon_percent = 50 set ledstrip_beacon_armed_only = OFF set sdcard_detect_inverted = OFF set sdcard_mode = OFF set sdcard_dma = OFF set sdcard_spi_bus = 0 set osd_units = METRIC set osd_warn_arming_disable = ON set osd_warn_batt_not_full = OFF set osd_warn_batt_warning = ON set osd_warn_batt_critical = ON set osd_warn_visual_beeper = OFF set osd_warn_crash_flip = ON set osd_warn_esc_fail = ON set osd_warn_core_temp = OFF set osd_warn_rc_smoothing = OFF set osd_warn_fail_safe = ON set osd_warn_launch_control = ON set osd_warn_no_gps_rescue = OFF set osd_warn_gps_rescue_disabled = OFF set osd_warn_rssi = ON set osd_warn_link_quality = OFF set osd_rssi_alarm = 20 set osd_link_quality_alarm = 80 set osd_rssi_dbm_alarm = 60 set osd_cap_alarm = 450 set osd_alt_alarm = 100 set osd_esc_temp_alarm = -128 set osd_esc_rpm_alarm = -1 set osd_esc_current_alarm = -1 set osd_core_temp_alarm = 70 set osd_ah_max_pit = 20 set osd_ah_max_rol = 40 set osd_ah_invert = OFF set osd_tim1 = 2560 set osd_tim2 = 2561 set osd_vbat_pos = 2159 set osd_rssi_pos = 396 set osd_link_quality_pos = 234 set osd_rssi_dbm_pos = 234 set osd_tim_1_pos = 234 set osd_tim_2_pos = 2392 set osd_remaining_time_estimate_pos = 234 set osd_flymode_pos = 65 set osd_anti_gravity_pos = 234 set osd_g_force_pos = 234 set osd_throttle_pos = 234 set osd_vtx_channel_pos = 2402 set osd_crosshairs_pos = 205 set osd_ah_sbar_pos = 206 set osd_ah_pos = 78 set osd_current_pos = 234 set osd_mah_drawn_pos = 234 set osd_motor_diag_pos = 234 set osd_craft_name_pos = 2088 set osd_display_name_pos = 394 set osd_gps_speed_pos = 234 set osd_gps_lon_pos = 234 set osd_gps_lat_pos = 234 set osd_gps_sats_pos = 234 set osd_home_dir_pos = 234 set osd_home_dist_pos = 234 set osd_flight_dist_pos = 234 set osd_compass_bar_pos = 234 set osd_altitude_pos = 234 set osd_pid_roll_pos = 353 set osd_pid_pitch_pos = 34 set osd_pid_yaw_pos = 234 set osd_debug_pos = 234 set osd_power_pos = 234 set osd_pidrate_profile_pos = 186 set osd_warnings_pos = 297 set osd_avg_cell_voltage_pos = 2167 set osd_pit_ang_pos = 234 set osd_rol_ang_pos = 234 set osd_battery_usage_pos = 234 set osd_disarmed_pos = 234 set osd_nheading_pos = 234 set osd_nvario_pos = 234 set osd_esc_tmp_pos = 234 set osd_esc_rpm_pos = 234 set osd_esc_rpm_freq_pos = 234 set osd_rtc_date_time_pos = 234 set osd_adjustment_range_pos = 234 set osd_flip_arrow_pos = 310 set osd_core_temp_pos = 234 set osd_log_status_pos = 234 set osd_stick_overlay_left_pos = 234 set osd_stick_overlay_right_pos = 234 set osd_stick_overlay_radio_mode = 2 set osd_rate_profile_name_pos = 23 set osd_pid_profile_name_pos = 2 set osd_profile_name_pos = 234 set osd_stat_rtc_date_time = OFF set osd_stat_tim_1 = OFF set osd_stat_tim_2 = ON set osd_stat_max_spd = OFF set osd_stat_max_dist = OFF set osd_stat_min_batt = ON set osd_stat_endbatt = OFF set osd_stat_battery = ON set osd_stat_min_rssi = ON set osd_stat_max_curr = OFF set osd_stat_used_mah = OFF set osd_stat_max_alt = OFF set osd_stat_bbox = OFF set osd_stat_bb_no = OFF set osd_stat_max_g_force = OFF set osd_stat_max_esc_temp = OFF set osd_stat_max_esc_rpm = OFF set osd_stat_min_link_quality = OFF set osd_stat_flight_dist = OFF set osd_stat_max_fft = OFF set osd_stat_total_flights = OFF set osd_stat_total_time = ON set osd_stat_total_dist = OFF set osd_stat_min_rssi_dbm = OFF set osd_profile = 1 set osd_profile_1_name = - set osd_profile_2_name = - set osd_profile_3_name = - set osd_gps_sats_show_hdop = OFF set system_hse_mhz = 8 set task_statistics = ON set debug_mode = NONE set rate_6pos_switch = OFF set cpu_overclock = OFF set pwr_on_arm_grace = 5 set scheduler_optimize_rate = AUTO set vtx_band = 5 set vtx_channel = 4 set vtx_power = 0 set vtx_low_power_disarm = UNTIL_FIRST_ARM set vtx_freq = 5769 set vtx_pit_mode_freq = 0 set vtx_halfduplex = ON set vtx_spi_bus = 0 set vcd_video_system = NTSC set vcd_h_offset = 0 set vcd_v_offset = 0 set max7456_clock = DEFAULT set max7456_spi_bus = 2 set max7456_preinit_opu = OFF set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 set displayport_max7456_col_adjust = 0 set displayport_max7456_row_adjust = 0 set displayport_max7456_inv = OFF set displayport_max7456_blk = 0 set displayport_max7456_wht = 2 set esc_sensor_halfduplex = OFF set esc_sensor_current_offset = 0 set frsky_spi_autobind = OFF set frsky_spi_tx_id = 42,177 set frsky_spi_offset = -46 set frsky_spi_bind_hop_data = 6,229,219,209,199,189,179,169,159,149,139,129,119,109,99,89,79,69,59,49,39,29,19,9,234,224,214,204,194,184,174,164,154,144,136,124,114,104,94,84,74,64,54,44,34,24,14,255,255,255 set frsky_x_rx_num = 0 set frsky_spi_a1_source = VBAT set cc2500_spi_chip_detect = OFF set led_inversion = 0 set dashboard_i2c_bus = 0 set dashboard_i2c_addr = 60 set camera_control_mode = HARDWARE_PWM set camera_control_ref_voltage = 330 set camera_control_key_delay = 180 set camera_control_internal_resistance = 470 set camera_control_button_resistance = 450,270,150,68,0 set camera_control_inverted = OFF set rangefinder_hardware = NONE set pinio_config = 1,1,1,1 set pinio_box = 255,255,255,255 set usb_hid_cdc = OFF set usb_msc_pin_pullup = ON set flash_spi_bus = 0 set rcdevice_init_dev_attempts = 6 set rcdevice_init_dev_attempt_interval = 1000 set rcdevice_protocol_version = 0 set rcdevice_feature = 0 set gyro_1_bustype = SPI set gyro_1_spibus = 1 set gyro_1_i2cBus = 0 set gyro_1_i2c_address = 0 set gyro_1_sensor_align = CW270 set gyro_1_align_roll = 0 set gyro_1_align_pitch = 0 set gyro_1_align_yaw = 2700 set gyro_2_bustype = SPI set gyro_2_spibus = 1 set gyro_2_i2cBus = 0 set gyro_2_i2c_address = 0 set gyro_2_sensor_align = CW0 set gyro_2_align_roll = 0 set gyro_2_align_pitch = 0 set gyro_2_align_yaw = 0 set i2c1_pullup = OFF set i2c1_overclock = ON set i2c2_pullup = OFF set i2c2_overclock = ON set i2c3_pullup = OFF set i2c3_overclock = ON set mco2_on_pc9 = OFF set timezone_offset_minutes = 0 set gyro_rpm_notch_harmonics = 3 set gyro_rpm_notch_q = 500 set gyro_rpm_notch_min = 100 set dterm_rpm_notch_harmonics = 0 set dterm_rpm_notch_q = 500 set dterm_rpm_notch_min = 100 set rpm_notch_lpf = 150 set flysky_spi_tx_id = 0 set flysky_spi_rf_channels = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 set stats = OFF set stats_total_flights = 0 set stats_total_time_s = 0 set stats_total_dist_m = 0 set name = TH II Freestyle set display_name = - set position_alt_source = DEFAULT profile 0 # profile 0 set profile_name = - set dyn_lpf_dterm_min_hz = 0 set dyn_lpf_dterm_max_hz = 250 set dterm_lowpass_type = PT1 set dterm_lowpass_hz = 100 set dterm_lowpass2_type = PT1 set dterm_lowpass2_hz = 200 set dterm_notch_hz = 0 set dterm_notch_cutoff = 0 set vbat_pid_gain = OFF set pid_at_min_throttle = ON set anti_gravity_mode = SMOOTH set anti_gravity_threshold = 250 set anti_gravity_gain = 5000 set feedforward_transition = 25 set acc_limit_yaw = 100 set acc_limit = 0 set crash_dthreshold = 50 set crash_gthreshold = 400 set crash_setpoint_threshold = 350 set crash_time = 500 set crash_delay = 0 set crash_recovery_angle = 10 set crash_recovery_rate = 100 set crash_limit_yaw = 200 set crash_recovery = OFF set iterm_rotation = ON set iterm_relax = RPY set iterm_relax_type = GYRO set iterm_relax_cutoff = 11 set iterm_windup = 40 set iterm_limit = 150 set pidsum_limit = 500 set pidsum_limit_yaw = 400 set yaw_lowpass_hz = 0 set throttle_boost = 4 set throttle_boost_cutoff = 15 set acro_trainer_angle_limit = 20 set acro_trainer_lookahead_ms = 50 set acro_trainer_debug_axis = ROLL set acro_trainer_gain = 75 set p_pitch = 46 set i_pitch = 90 set d_pitch = 32 set f_pitch = 95 set p_roll = 42 set i_roll = 85 set d_roll = 30 set f_roll = 90 set p_yaw = 30 set i_yaw = 90 set d_yaw = 0 set f_yaw = 90 set angle_level_strength = 60 set horizon_level_strength = 30 set horizon_transition = 80 set level_limit = 30 set horizon_tilt_effect = 75 set horizon_tilt_expert_mode = OFF set abs_control_gain = 0 set abs_control_limit = 90 set abs_control_error_limit = 20 set abs_control_cutoff = 11 set use_integrated_yaw = OFF set integrated_yaw_relax = 200 set d_min_roll = 0 set d_min_pitch = 0 set d_min_yaw = 0 set d_min_boost_gain = 27 set d_min_advance = 20 set motor_output_limit = 100 set auto_profile_cell_count = 2 set launch_control_mode = NORMAL set launch_trigger_allow_reset = ON set launch_trigger_throttle_percent = 20 set launch_angle_limit = 0 set launch_control_gain = 40 set ff_interpolate_sp = AVERAGED set ff_spike_limit = 60 set ff_max_rate_limit = 100 set ff_boost = 13 set idle_min_rpm = 0 set idle_adjustment_speed = 50 set idle_p = 50 set idle_pid_limit = 200 set idle_max_increase = 150 rateprofile 0 # rateprofile 0 set rateprofile_name = - set thr_mid = 25 set thr_expo = 50 set rates_type = BETAFLIGHT set roll_rc_rate = 65 set pitch_rc_rate = 65 set yaw_rc_rate = 80 set roll_expo = 65 set pitch_expo = 65 set yaw_expo = 20 set roll_srate = 70 set pitch_srate = 70 set yaw_srate = 60 set tpa_rate = 25 set tpa_breakpoint = 1650 set tpa_mode = D set throttle_limit_type = SCALE set throttle_limit_percent = 75 set roll_rate_limit = 1998 set pitch_rate_limit = 1998 set yaw_rate_limit = 1998 # end the command batch batch end # • Posts: 46 Threads: 18 Likes Received: 1 in 1 posts Likes Given: 0 Joined: Sep 2020 Reputation: 0 For some reason when the motors running in the wrong direction so I was trying to correct it and use BLHELI . In the process of changing it I can’t even test the motor in betaflight • Posts: 4,550 Threads: 38 Likes Received: 1,245 in 1,064 posts Likes Given: 430 Joined: Aug 2020 Reputation: 118 Did you mean motor order or motor direction? What are you remapping? • Posts: 46 Threads: 18 Likes Received: 1 in 1 posts Likes Given: 0 Joined: Sep 2020 Reputation: 0 So yes I was trying to remap the motors because motor 1 was motor 4, and so were other ones. I also need to change the directions of the motor as well thank you • Posts: 21,263 Threads: 587 Likes Received: 8,969 in 6,637 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 788 If you are still running the original TinyHawk FC then you don't need to do any motor remapping. First of all, put your motor mapping back to the defaults by running the block of commands below in the CLI. This is the default mapping for the TinyHawk II Freestyle. Then we can start helping you to sort out the correct motor directions using BLHeli software. Code: resource MOTOR 1 B06 resource MOTOR 2 B08 resource MOTOR 3 B10 resource MOTOR 4 B07 save
• Posts: 2,358 Threads: 118 Likes Received: 812 in 659 posts Likes Given: 128 Joined: Feb 2021 Reputation: 20 I briefly read through this .. if al u did was swap motors, they are going to be mapped correctly.. HOWEVER they may rotate different.. you are unable to change the direction in BLHELI because of one of two reasons.. these are “S” not “32” so u need to use BLHELI configurator .. or. You need to have a battery powering the ESCs for the program to identify them.. • Posts: 46 Threads: 18 Likes Received: 1 in 1 posts Likes Given: 0 Joined: Sep 2020 Reputation: 0 Ok thank you guys I really appreciate it, still working but I would work on this evening thank you • Posts: 46 Threads: 18 Likes Received: 1 in 1 posts Likes Given: 0 Joined: Sep 2020 Reputation: 0 I remapped the motors. I didn’t notice that I couldn’t arm the quad any longer I’m now getting a error message cli screen I had issues seeing the rotation of the motor in betaflight or able to arm but I do see the stick movement in betaflight • Posts: 4,550 Threads: 38 Likes Received: 1,245 in 1,064 posts Likes Given: 430 Joined: Aug 2020 Reputation: 118 What exact FC do you have on your quad? And show us a photo. • Posts: 2,358 Threads: 118 Likes Received: 812 in 659 posts Likes Given: 128 Joined: Feb 2021 Reputation: 20 Maybe he flashed the wrong firmware or one point. If I remember it should be matek411rx.. • |
