14-Feb-2024, 10:09 PM
Hi, im new to fpv drones and i just build one. I have a SkyStars F722 HD Pro 4 and a walksnails Avatar HD v2 kit. The problem is, whatever i do, i cant make the VTX to show Ready in betaflight. I soldered my VTX TO FC, by switching TX/RX between FC and VTX, to UART4. For power i use the +10V pad next to UART4. I use the 4.4.3 firmware and i followed this tutorial to set the VTX : [color=var(--text-link)]https://oscarliang.com/setup-avatar-fpv-system/#Connecting-Air-Unit-to-FC[/color].
In Port tab i select VTX(MSP+Displaypot), MSP function automatically is selected, i go to Presets tab and select OSD for Fpv.wtf, DJI O3, Avatar HD preset then the ExpressLRS 250 Hz preset, i select HD in the OSD tab. After i save and reboot in the Video Transmitter i can see "VTX Type: MSP' but Device Ready is False. On the FC i have some pads for PIT and +5/+10V mode. The 3 pads for PIT mode are soldered to PIT and the pads for voltage are soldered for 10V.
In Modes tab i have a User1 mode set for switching the VTX PIT on and off. Its working because if i flip the switch to PIT mode the green led from VTX go off, when i flip back the switch the green led start to blinck again. But when i arm my drone and fly it my camera doesnt record. I can access its internal memory and is empty. I dont have my googles yet since they are more expensive than my drone but i will buy them later. The VTX go ready only it is paired with the googles? Because so far what ever i do i cant make the internal DVR of the VTX to record video. I ve tried to find some help to Discord channels but all of them pointed me to the same link from oscarliang.
The only thing i havent done yet is to give up and declare the VTX faulty, but i hope someone here could help me fix this problem
