Podracer build oscillating into the sky
I had a good build with the source podracer using the JHEMCU UPDATED GHF411 PRO AIO but every time I landed slightly too hard it would fry the entire board so I went with the HAKRC F722 2-6S AIO instead because it had an mpu 6000 and now it's back to flying away due to oscillations. I have 2 1000uf capacitors soldered directly to the board with 20 gauge wire with less than 3cm of wire on each. I had the same problem with the JHEMCU, but just 1 capacitor was enough to fix it and it flew well until I fried every board I had.
do you get runaway protection?
check the rigidity of your arms, delaminated carbon can cause that
(13-Jun-2022, 12:05 AM)hugnosed_bat Wrote: do you get runaway protection?
I don't get runaway protection activating, I've been manually disarming because of how fast it goes up.
Look for shorts on the AIO board. Something must be causing the motors to spin at wild and the FC is unable to detect a runaway.
I turned the maximum motor power down to 85% and did a test flight with rolls flips and full throttle ramp ups and there is definetly lots of noise, but it goes crazy on the last ramp up
https://drive.google.com/file/d/1SVEsz0R...sp=sharing
I have PodRacer frame. Its good and stiff.
90% its the PID causing this.
Try low safe values like P20 I20 D10.
  Build Rekon5 UL 5" build ph2t 51 8,072 12-Apr-2024, 02:26 AM
Last Post: ph2t
  Build Micro Apex 4" Build drumgod 8 427 11-Apr-2024, 12:05 AM
Last Post: BigBeard
  Build Helios - 3.5” Sub-250g (Sub 160g possible) DJI O3 Drone – Frame/Build Thread Recursion 12 1,892 25-Mar-2024, 10:28 PM
Last Post: Recursion
  Build 5in lightweight build hawk01 37 1,422 22-Mar-2024, 10:56 AM
Last Post: Jossey
  Build Whoosh - 3.5" build. PID settings? maxer 23 1,200 30-Dec-2023, 08:29 PM
