When I toggle my right bottom switch on remote control (AUX4), I need PWM signal from TBS receiver to the cam switcher to be sent. Please tell me how can I setup TBS receiver so it will send this PWM signal?
I use Radiomaster TX12 transmitter. I also have TBS Crossfire Nano:
If I understand correctly, in this video (https://youtu.be/zEWlYpDZuS0?t=1155) at 19:15, the guy is binding (mapping) receiver's phyisical pins 1-8 to receiver's channels (among them my AUX4). Although he has TBS Crossfire with more pins (CH1-CH8) and I have just TBS Crossfire Nano (CH1-CH4), but logic must be the same.
So if I map Output4 (on my image it seems to be third pin from the top) to signal CH4 (or possibly CH8 since ch1-ch4 are controls, ch5-ch8 are AUX maybe), will it produce signal on that pin? Please clarify what should I do to obtain the PWM signal.
Thank you in advance!
