02-Jun-2020, 12:27 PM (This post was last modified: 16-Nov-2020, 10:43 AM by iFly4rotors.)
2020-06-02 Phantom-i Last Post : My Journal
Having completed the Phantom-X project and having sufficient spare parts, I decided to build a "standard" GEPRC Phantom. The idea was to take a GEPRC Phantom frame, GEPRC Stable F411 stack, GEPRC motors, and a FrSky XM+ receiver (all standard on the GEPRC Phantom) and assemble a quad that was basically a home built GEPRC Phantom. The only non-standard components were the Foxeer camera, a VAS Minion Pro VTX antenna, and a BetaFPV buzzer.
After the initial assembly, there was an issue with the motors. It appeared as thought the ESC was not working correctly. Since I was not inclined to diagnose the issue at this time, I decided to swap the GEPRC stack for an iFlight SucceX Micro F4 V2.0 Flight Tower System 16x16 (ESC Plugs) that I wanted to test anyway. I thought this would be an expedient option since the motor connector sockets were already factory installed and would make things go a little quicker. Also, this stack has on-board memory for the Blackbox. So now, I decided to call this quad Phantom-i due to the use of an iFlight stack.
Regarding the flight controller stack. I had purchased the iFlight SucceX Micro F4 V2.0 Flight Tower System 16x16 (ESC Plugs) because it comes with the motor connector sockets factory installed which would facilitate installation of motors with plugs. I had expected this installation to go smoothly. The only soldering was the connection of the XM+ receiver, the Buzzer, and the power wire. Once the wires were soldered and the stack was fitted to the frame, I realized that the motor plugs interfered with installation of the camera and the receiver & buzzer wires. To get everything connected, the stack was separated, all connections made, and the stack re-assembled. Even now, one of the motor sockets had to be bent forward a little to get the boards (header pins) to completely connect. Another minor irritation is the placement of the power wire connection pads that are directly below the USB port which made connecting the stack to the computer a little cumbersome. I finally got the power wires tucked in so that the USB port is now accessible, however, it looks a little “clunky” to me. In any case, it was now together.
As it turns out, this stack with the connectors presented more challenges than it should have. In the future I would buy the “sister” stack that comes without connectors. I would rather solder my own motor connectors or solder the motors directly, depending on the build.
Upon bench testing, I noticed that all of the motors were spinning in a clockwise direction! Two were correct and two were not. I checked Betaflight and everything looked fine. Having some knowledge of these motors, I know that reversing two of the motor wires would change the direction. Ok, so now I made a couple of “bridge” connectors with two of the wires reversed. Now, three motors were spinning correctly, but one was still not right. Upon remaking one of the bridge connectors, switching different wires, all the motors are spinning in the correct direction.
NOTE: I am not sure if this is common with the iFlight stack or just something to watch out for.
The final step was adding the VTX, camera, and buzzer. Since everything here is plug-and-play, the final assembly went smoothly. The fully completed quad’s dry weight is 78 grams; this is without battery and with no a ViFly buzzer which I have now added. Yeah, I have two buzzers on this thing.
Next, we move to final "in-house" testing. Everything worked as expected. The quad armed fine, took off when throttle was applied, responded well to stick movement, and hovered fine.
Since my fly field is still shut down due to coronavirus , the flight testing and videos will be added later.
Jump to most recent post HERE
