Phantom 4n1 substitute or replace?
I was flying my phantom and it did a death roll and I tried taking off again and 50 feet away it death rolled again.
 I unplugged LiPo and tried again and one motor started sputtering and I am almost certain one ESC gave out.
  I tried a few times later and the motor/ESC in question gets a bit warmer then the others so I will likely verify it’s the ESC and order a new one or get a upgrade.
   I find it kind of strange that flying along the esc gives out after no prop strikes or flipping upside down and not disarming fast enough.
 I have blown ESC before and it’s usually from a prop strike or obstruction but to have a esc go out during flight at 1/2 power has never happened.
  It takes this 4n1 and if there’s a beefier one maybe it will hold up longer or I just got a dud?
  I haven’t tore stack down but checked wires and soon will try a different motor.
 From experience it behaves like a blown ESC but a different motor will verify.
 Is there any 16 by 16 4n1 ESC that would be a better choice for phantom or just get original?
Electronics in this hobby aren't the best quality. I am never surprised anymore with DOA electronics or a few uses.
I don't have a suggestion for your replacement. I would just buy from a good manufacturer. Although you might have to deal with rearrange harness cable.
  • Rob3ddd
  Can a 40amp 4n1 handle 7” on 4S? Rob3ddd 6 380 30-Aug-2021, 05:51 PM
Last Post: Rob3ddd
  Setting up Hobbywing 60amp 4n1 questions Rob3ddd 1 343 17-Oct-2020, 03:20 PM
Last Post: Sugs
  new GEPRC Phantom HD Motor not spinning up hutch08 2 813 04-Oct-2020, 11:49 PM
  Discussion Motors to replace Cobra 2204's? Sigloss 15 3,674 24-Aug-2016, 12:02 PM
Last Post: HamsterFPV
