Hello,
A few weeks ago i built a pepperf1sh clone with racerstar parts (F3D8 FC and Star4A ESC). It was awesome and fun. Although I'm not a good pilot I missed some extra power. : So i decided I'm going to build this tiny mosquito on 2S. The original pepperF1SH FC (Tinyfish) can handle up to 3S battery and fortunately the clone also can (it was confirmed on rcgroups). So I needed a light 16x16mm ESC. At that time Simon (author of pepperf1sh) had only a prototype version for 2S and his design wasn't released by Furious FPV so I needed an alternative. Fortunately Racerstar made a 2S capable 16x16mm ESC and the specs are pretty close to Simon design. Last week I received the clone FC and the ESC:
and two days ago I got the battery (2S 400mAh, 22g) which is not the final version (I'm still waiting them) but finally I had all the parts and I was able to build this tiny quad.
Here is part list:
Here are some close-up pictures from the ESC:
All AIOs max input voltage is 5,5V so I had to figure out something to feed the camera. As I read somebody was able use the AIO on 2S but I think it's not the best practice. I don't want to use a step-down converter so I decided to use balancer connector only to power the quad and I use one cell from the balancer plug to power the AIO:
It's working quite well. After a 4 mins hovering the cells were 3,80V and 3,85V so there was no huge imbalance between them.
The total weight with this temporary battery(22g) is 54g. The final battery is only 16g so it will ended somewhere 48g.
Unfortunately I was able to perform just a hovering test in my flat but it has much more power. Tomorrow I'm going to fly it on our field
Here is part list:
- Racerstar F3D8 - FC (pepperf1sh clone)
- Racerstart STAR6A - ESC
- Racerstart BR1103B 10000kV - Motor ***EDIT: I didn't like the quality of the Racerstar motors so I changed them to RCX RS1103 7800kV
- FX805 AIO - Camera (I prefer this camera over the Eachine TX01 as it handles the light changes better)
- Turnigy nanotech 300mAh 2S - Battery
- 86mm m2m distance, 1mm CF thickness - Frame (own "design")
