Threads: 28
Likes Received: 34 in 21 posts
Likes Given: 153
1 that is good to know, but can you tell a little bit more about the overkill part? xD or can you suggest alternative to Tekko32F3 Metal?
Threads: 125
Likes Given: 99
388 The Tekko32 are quite thick. Make sure you have the headroom on your build for the stack.
The other disadvantage to 4in1 is, when your ESC lights up in fire, it usually takes any component above it too. You end up not only replacing the 4in1 but the FC too.
Also if you have different pin connectors on the FC and 4in1, it is not just plug and play. But that will not apply to you.
Threads: 28
Likes Given: 153
1 What are the situations when 4in1 ESC would burst into the flames? Some bad wiring? Crash?
Threads: 125
Likes Given: 99
388 Crashes, overloading with current (likely not with 65A), bad manufacturing, some kind of short circuit, incorrect wiring, and idiopathic. Basically like any other electrical component.
Threads: 59
Likes Received: 592 in 395 posts
Likes Given: 210
42 I recommend purchasing a esc/fc "Stack" that comes together, they have the harness to connect them together already made, and you can just hook up, cam/vtx/rx and solder your batt leads and motor wires and you're done. Super clean, neat and tidy. And if you're not the best at soldering you don't have to struggle with all the extra ESC power and signal wires.
I can build a quad with a 4in1 in about half the time... For instance the tekk32 esc's come without the wires pre-soldered, so assuming:
VTX 4 Solder Joints
RX 3 Solder Joints
Cam 3 Solder Joints
Motors 12 Solder Joints
Batt Lead 2 Solder Joints
Individual esc (x1) 8 solder Joints (x4) 32 Solder Joints.
So For Individual ESC's you have 56 Solder Joints for a full build assuming you're using a FC with a good inbuilt PDB, and for a 4in1 you have 24 solder joints if you get a "stack".... I say go 4in1 since there isnt so much reliability or price differences these days.
