Threads: 118
Likes Given: 128
20 I started using esc comfig when it offered Bluejay … bi-directional d shot, played a part and I had purchased jesc license for my esc to be able to use bi-dir-d..
I have used it, positive results, and will continue using it for BLHELI s ESCs … if / when I get a Blheli32 esc I’ll use BLHELI suite..
This was another “hurdle” I had to discover the other n my own.. I had no idea there was DIFFERERNT BLHELI and u had to use different programs for each
Threads: 61
Likes Received: 1,030 in 743 posts
Likes Given: 97
53 I use it a lot, wonderful that it is browser based as well. I believe it has a very large user base in the fpv community for flashing bluejay and I have not heard of any issues with it. It is also actively maintained and the devs are very helpful/responsive. Its been many years since I've use Blhelis configurator.
Threads: 76
Likes Received: 1,370 in 1,025 posts
Likes Given: 800
41 I use all of them. I use the website version and I still use BLHeli for two pain in the ass quads that won't work with Bluejay. They both do the job. But I find the web version you have to unplug USB to get it to reconnect after disconnecting and sometimes close the browser and redo it. It's like the web implementation opens the socket for the USB then doesn't release it when you disconnect. But it's not critical or anything.
Try Not, Do or Do Not
- Yoda
Threads: 76
Likes Given: 800
41 Devuan Linux (Debian Linux without the crap). I'm not a Windows user. I assume Cura is for Windows. At least i've never heard of it on Linux.
TBH, I think some of it is Chrome and some of it is whatever back end they use. It only happens on esc configurator and none of the others. It also doesn't happen when using the builtin esc configurator on Quicksilver.
- Yoda
Threads: 21
Likes Received: 303 in 221 posts
Likes Given: 319
6 16-Feb-2024, 04:27 AM (This post was last modified: 16-Feb-2024, 04:27 AM by QuadFlyer68.) +1 for ESC-Configurator.com
_____________________________________
Walksnail / Avatar … It’s better than analog !
Threads: 34
Likes Received: 282 in 190 posts
Likes Given: 46
6 I have been using the web ESC configurator for a long time and quite often. During the entire time, it happened twice that one of the 4 ESCs in the 4in1 ESC failed to be updated. Which means bricked ESCs specifically 2 pieces. If this happens, you're screwed. And nothing else will help, than the classic old BLheli-s configurator and a small arduino, otherwise there is no chance to put the bricked ESC back into operation. So that's my experience with the web version of ESC-configurator.
