Threads: 21
Likes Received: 143 in 72 posts
Likes Given: 62
6 It's not the same reciever (but it's quite similar) so maybe this video could help you
I've used the FS-iA6B before one an f3 board and you only have to conect the reciever by ibus to a free uart of the f3 and in betaflight configure in ports that uart as serial rx, and then in configuration page of betaflight select ibus
Threads: 29
Likes Received: 279 in 168 posts
Likes Given: 242
6 30-May-2018, 02:00 PM (This post was last modified: 30-May-2018, 02:01 PM by Hypurr.) I started with the exact same RX, came with my first TX, too. After I learned quite a bit it ended up in the trash, the big clunky monstrosity it is. I had to remove the plastic case to make it fit in my first build and then it barely did and took up far too much room. I had IBUS working on it but it's been awhile so I don't remember the details but here's a video that has specific instruction on that particular RX.
Threads: 3
Likes Received: 1 in 1 posts
0 I connected the receiver to the FC as explained in these videos. Now it is on UART2, everything in betaflight is set up, but it still shows me only zeroes. What could be the problem? May the receiver be faulty?
Threads: 3
0 Yes, I have everything setup and it still doesn't show me the values.
Threads: 29
Likes Given: 242
6 Post a picture of the RX and how you have it connected.
Threads: 3
0 I solved the problem. All it took was updating the firmware. Thank you all for your help.
