old an needs help with Babyhawk Pro
Good morning guys i'm having problem setting up aBabyhawk pro. I flashed the firmware and when i got to the motors tab the #1 motor is in #2, #2 is in #3, #3 is in #3 and #1 is in #4. I went into cli and in the list the drone appears with 7 motors. Does somebody have an idea of what am i doing wrong.
I found a config dump online, and they are indeed mapping stuff to motors 5, 6 and 7. So there's definitely some shenanigans going on. But there seem to be about 8 versions of the Babyhawk, so it's anyone's guess.
Babyhawk Pro BF3.5 config
Did you definitely flash the correct firmware? It looks like it should be using OMNIBUSF4. Also, which version of BF did you flash?
you can write „resource“ to the cli and it will display the display the motormapping. you can change the resource. but if you can tell the specific version of your babyhawk? the 4inch? the 3inch? you can probably find the right mapping without work.
Just because there are 7 motors, it doesn't mean you have breakouts for all 7. It is very common, especially if the FC does not have it own target.
Anyway, just remap the motors that are incorrect to the correct ones. BTW, you said that motor #2 and #3 are mapped to #3 motor?
(24-Sep-2019, 02:51 PM)Banelle Wrote: I found a config dump online, and they are indeed mapping stuff to motors 5, 6 and 7. So there's definitely some shenanigans going on. But there seem to be about 8 versions of the Babyhawk, so it's anyone's guess.
Downloaded MATEKF405 as indicated in a small instruction booklet,i also checked in beta flight and that is the correct firmware.Can i change the order of the motors in Betaflight? and if possible how is it done or i can find it in Youtube. thank you.
(24-Sep-2019, 03:54 PM)voodoo614 Wrote: Just because there are 7 motors, it doesn't mean you have breakouts for all 7. It is very common, especially if the FC does not have it own target.
Yes the motors are all mixed up #1 is #4_#2 is #1 -#3 is #4-and #4 is #3. I responded to BONNET that if it is possible to change the order in BETAFLIGHT and if there is in YOUTUBE a video. THANKS
https://oscarliang.com/betaflight-resource-remapping/
  • hugnosed_bat
  BetaFPV Meteor65 Pro SeismicCWave 97 1,716 Yesterday, 07:02 AM
  Build BetaFPV Meteor65 Pro 1S Build brettbrandon 30 775 14-May-2024, 06:03 PM
Last Post: brettbrandon
  Converted to Meteor65 from Pro SeismicCWave 33 634 13-May-2024, 06:22 AM
  Betafpv Meteor 75 Pro flying jittery and flyaways...[SOLVED] baevans11 5 212 10-May-2024, 11:41 PM
Last Post: segler999
  Meteor65 pro walksnail build, 24g. ph2t 2 165 07-May-2024, 04:11 AM
Last Post: FPVme
