Threads: 38
Likes Received: 7 in 4 posts
Likes Given: 12
0 Good morning guys i'm having problem setting up aBabyhawk pro. I flashed the firmware and when i got to the motors tab the #1 motor is in #2, #2 is in #3, #3 is in #3 and #1 is in #4. I went into cli and in the list the drone appears with 7 motors. Does somebody have an idea of what am i doing wrong.
Threads: 50
Likes Received: 832 in 504 posts
Likes Given: 372
51 24-Sep-2019, 02:51 PM (This post was last modified: 24-Sep-2019, 02:54 PM by Banelle.) I found a config dump online, and they are indeed mapping stuff to motors 5, 6 and 7. So there's definitely some shenanigans going on. But there seem to be about 8 versions of the Babyhawk, so it's anyone's guess.
Babyhawk Pro BF3.5 config Did you definitely flash the correct firmware? It looks like it should be using OMNIBUSF4. Also, which version of BF did you flash?
The ground is for dead people.
Threads: 172
Likes Given: 4,721
100 you can write „resource“ to the cli and it will display the display the motormapping. you can change the resource. but if you can tell the specific version of your babyhawk? the 4inch? the 3inch? you can probably find the right mapping without work.
Threads: 125
Likes Given: 99
388 Just because there are 7 motors, it doesn't mean you have breakouts for all 7. It is very common, especially if the FC does not have it own target.
Anyway, just remap the motors that are incorrect to the correct ones. BTW, you said that motor #2 and #3 are mapped to #3 motor?
