Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 19-Aug-2017, 08:47 PM (This post was last modified: 21-Feb-2018, 07:21 AM by Drone0fPrey.) Major frustrations before vacation. Decimated and ESC 12hrs before I left. No replacement on hand, no flying on vacation... Suck a bag of A zip-tie failed in a crash allowing my ESC to hit prop Pulling off the positive power wire and cap with it, separated the PCBs, lost some sort of chip lol, and another tiny capacitor. To be honest I could have repaired it if it weren't for the missing chip. Anyways now I am home. Have a new ESC. Everything is installed but the Racerstar MS35A does not show up in bl_suite or spin the motor in BF. I have tried calibrating several times as well as triple checked all solder joints. Power is being applied, as I have checked with a multimeter and compared it to the rest of the other ESCs. Everything seems fine. My questions: Is it just a bad ESC? And if so, is there a way to get it communicating? Or could it be the PWM it was connected to on the FC? • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 20-Aug-2017, 12:53 AM (This post was last modified: 20-Aug-2017, 12:56 AM by sloscotty.) Maybe you damaged the header output on the FC when the ESC was ripped out? You might try soldering the signal to output 5 or 6 (if available) and then remap the motor output in Betaflight. (I haven't looked at this recently, but you usually did this in CLI. Joshua Bardwell had a good video on it - but things may have changed with more recent versions. Just Google "remap motors betaflight".) This assumes that your new ESC has no problems - if you are not sure, you can check it stand-alone with a servo tester. Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 I was remapping resources for my wing configuration, take a look at my comment here: http://intofpv.com/t-building-a-first-wi...0#pid27050 • Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 Thanks guys. I'll be looking into it more today. • Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 Identified my problem. When I removed the epoxy around the signal wires, I damaged a tiny capacitor. Stole some from a scrap PCB and so far so good.... After a few mishaps, one of which popping my darn FC. Rowdy kids while using a multimeter... Wont happen again lol Between this and fixing mosfets on Quadstyles QX90, my soldering game has been upped Posts: 1,590 Threads: 89 Likes Received: 1,283 in 768 posts Likes Given: 1,274 Joined: Jan 2017 Reputation: 31 (29-Aug-2017, 12:36 PM)Drone0fPrey Wrote: Identified my problem. When I removed the epoxy around the signal wires, I damaged a tiny capacitor. Stole some from a scrap PCB and so far so good.... After a few mishaps, one of which popping my darn FC. Rowdy kids while using a multimeter... Wont happen again lol Between this and fixing mosfets on Quadstyles QX90, my soldering game has been upped That thing is tiiiiiny! carl.vegas Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250 • Posts: 2,286 Threads: 38 Likes Received: 1,527 in 995 posts Likes Given: 1,881 Joined: Apr 2016 Reputation: 72 I HATE those MS series ESCs! I made the mistake of buying them for my Armattan Hex. When I found that they'd epoxied those stupidly thick signal wires, the air in here was decidedly blue for some time afterwards. There was no way I could have fitted 12 of those wires on top of the flight controller and still get the top plate on, so I was forced to trim them all, solder on 30AWG extensions and shrink wrap each wire. I really wasn't a happy quad builder that evening. I'll bet they thought it was a good idea at the time. Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 I like electrical tape on my ESCs. Not the prettiest or cleanest look, but less likely to fail compared to zip tie. Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 Posts: 2,286 Threads: 38 Likes Received: 1,527 in 995 posts Likes Given: 1,881 Joined: Apr 2016 Reputation: 72 (01-Sep-2017, 02:37 PM)Drone0fPrey Wrote: Right! I hate that super hard epoxy too. Any tricks for removing it in the future? Besides not buying the MS series again I haven't been the fuzzy feelin "tinkerer" I usually am. There's no way to remove the glue that doesn't risk damaging the ESC. Removing it by physical means is out, as you already discovered, and I can't think of any chemical means that would only affect the glue. I'd say that the "don't buy them" option is the best! Posts: 1,590 Threads: 89 Likes Received: 1,283 in 768 posts Likes Given: 1,274 Joined: Jan 2017 Reputation: 31 02-Sep-2017, 12:04 PM (This post was last modified: 02-Sep-2017, 12:05 PM by Carl.Vegas.) (02-Sep-2017, 09:46 AM)unseen Wrote: I'd say that the "don't buy them" option is the best! how to fix them: - Win sunnysky ones from the contest on here
- Replace them.
- lol
That look right to you Unseen? carl.vegas Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250 Posts: 2,286 Threads: 38 Likes Received: 1,527 in 995 posts Likes Given: 1,881 Joined: Apr 2016 Reputation: 72 (02-Sep-2017, 12:04 PM)Carl.Vegas Wrote: That look right to you Unseen? Sure does! • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 (02-Sep-2017, 12:04 PM)Carl.Vegas Wrote: how to fix them:- Win sunnysky ones from the contest on here
- Replace them.
- lol
That look right to you Unseen? I guess you decided to go with the first option Carl. Congrats! |
