New batteries not holding charge
Hey there,
I am newcomer into the world of FPV. I got a Eachine Q90C as a gift recently and I wanted more batteries as flying for 5 minutes and then charging for 40 can be tiresome. I ordered a this set of batteries as they have the same specs as the stock one. only more capacity (300mAh vs 400 mAh). But when I fly with the new batteries my controller starts vibrating(indicating low battery) in just a minute so I'm wondering what I am doing wrong? Is my charger bad? are my batteries bad? I charge them with the same charger as the stock battery and I can fly for around 4-5 minutes with that one.
Thanks in advance
Nooooooo.....
Your quad uses 1S batteries, but those spare batteries you bought are 2S! That's probably why they are not charging with your charger because they are meant for 1S batteries. And you are lucky you haven't burned the quad yet.
(15-Nov-2017, 12:40 PM)Oscar Wrote: Nooooooo.....
Are you sure? The stock battery is 7.4v which is normally 2s right?
Edit: I timed the flight difference between the batteries, and I got a low battery notice after 25 sec on the new batteries, while the stock battery took 2 and a half minute to start sending the signal
Yeah, 2S is correct for this model.
There are only two possible explanations for why you get a low battery warning so quickly:
1. The new batteries are rubbish.
2. The extra 7g weight compared to the 300mA/h battery causes a large increase in motor current.
(15-Nov-2017, 06:50 PM)unseen Wrote: Yeah, 2S is correct for this model.
Yes I was suspecting the first point. Could my charger not be charging them fully for some reason? It's a basic USB cable charger.
it has the following text printed on the back:
Input: DC 5V 2A
Output: 7.4V ----500mA
If it charges the original battery properly, it will also charge the new batteries properly.
Unfortunately, buying batteries from Banggood is often a pot luck kind of thing. Some of them are great and some are just terrible.
Seeing as you're in The Netherlands, I'd advise you to have a look at Hobbyking's EU warehouse. They have some very good 2S batteries that will give you much better results. Something like this: https://hobbyking.com/en_us/turnigy-nano...-pack.html
There's quite a few to choose from in the 300 - 400mA/h 2S class.
oops, sorry my fault, i looked at the spec and it was the Googles' not the quads LOL Smile
I would suggest to check the voltage of the batteries after charging, making sure they are indeed charged fully at 8.4V. If it's lower than that then there is probably a problem with either the charger or the batteries...
If you still have problem with power, then it's definitely the batteries that are bad.
easy way to check,
grab a multimeter and check voltage if after charge it is close to 4 /6 if you can check per cell look for range 3.7-4.2 per cell - something is wrong ... charger/battery
do the same with original battery as a comparison then you will see which part is crap.
other part check what is the output out of your charger 500 ma or you maybe have a meter that is showing amoung of mah pumped into the battery, see or try to calculate how much it is..
last thing... what conditions you are flying ? if your batteries were in the trunk of your car and it is close to 0 deg... they will perform poorly.
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
(19-Nov-2017, 10:23 AM)Grisha0 Wrote: also a easy way to check,
yes by all means get yourself a voltage tester for 1-8s batteries
this is one i've had for about 4 years and has held up
https://www.banggood.com/Wholesale-1S-8S...rehouse=CN
you may have a bad cell or a low cell and battery should be balanced .
also a gang charger / charging board and balance charger should be in your future...
many years ago i bought a imax b6 and it has lasted and is a old standard.
https://www.banggood.com/Wholesale-IMAX-...ehouse=USA
 if you get a parallel charging board make sure it has the correct connectors!!
BTW: banggood has always replaced any faulty item i've bought and so has hobbyking
both require a quick vid post it on your youtube page
  Wiring batteries together DragonTheta 19 1,681 12-Mar-2024, 03:41 PM
  Help Autel evo 2 pro batteries DC nordiC 5 371 14-Nov-2023, 02:24 AM
Last Post: DC nordiC
  lithium polymer batteries hawk01 6 349 24-Oct-2023, 12:51 PM
Last Post: hawk01
  Charging 2S batteries via the Balance lead Cyberess 8 532 01-Oct-2023, 03:04 PM
Last Post: Cyberess
  is parallel charging worth the risk for multi cell batteries? B4tn 14 990 23-Jun-2023, 06:37 PM
Last Post: Rob3ddd
