14-Nov-2023, 10:37 AM
Hello, I have some questions related to filters and the settings to use in camera.
First question: filters are a must have? Some users say to use them always, others to use them sometimes and others to never use them on drones. What do you think about it?
To my understanding the main usage in drones is to obtain motion blur and stick to the 180° rule and to reduce the amount of light hitting the sensor ND filters are needed. With FPV there are two issues: to have a consistent exposure is not a good idea to use manual settings because you are continually changing direction and if you follow 180° rule and then you use EIS or apply stabilization with Gyroflow the footage will probably be crap and even Gyroflow documentation suggests to stick to 90° or 45° shutter angles. Do you use full Auto settings? Or do you manually set the shutter and use Auto ISO or the other way around? For example I've seen a Joshua Bardwell video about this topic and he uses fixed iso and Auto shutter + an ND filter if needed. What settings do you use? Are filters really necessary in your opinion?
