Cleanflight vbat settings
Hey everyone,
i need some clarification about the battery monitoring in Cleanflight. Couldn't find any exact statement on google :/
So you have
vbat_scale = 112
vbat_max_cell_voltage = 42
vbat_min_cell_voltage = 33
vbat_warning_cell_voltage = 35
Scale is obvious.
The max voltage is clear too.
Now my problem:
It's said that both min and warning trigger the alarm. Is is triggered differently?
What is the exact differenc for calculations, etc. between min and warning?
Can i set them to the same amount, does that make any sense?
Cheers
Diego
Sky is where the fun begins!
Flying: Armattan F1-6 / Cobra 1960kv / KISS / 1800mAh nano's / SPR3 / Betaflight 2kHz
Building: FPV49v4 modified
(19-Jan-2016, 10:06 PM)DiegoTheWolf Wrote: Hey everyone,
So you have
vbat_scale = 112
Scale is obvious.
Now my problem:
Cheers
Diego
I don't know the specific calculations but I can tell you the behavior of each.
Warning voltage will make your buzzer start chirping every second and and min voltage will set off the continuous beeeeeeeep.
(19-Jan-2016, 11:39 PM)Arknabbit Wrote: Warning voltage will make your buzzer start chirping every second and and min voltage will set off the continuous beeeeeeeep.
Thanks !! Will there be a diffrent warning in the OSD or the same "Low Voltage" ?
What OSD are you running?
minimOSD with MWOSD 1.5
to be honest i don't find any difference between vbat_min_cell_voltage and vbat_warning_cell_voltage, apart from making the alarm to go off...
Set it to whatever values you want it only affects when your alarms is triggered depends on voltage... i set mine to 2V so it never sounds Smile because it's annoying!
  Video ND Filter settings and opinions Maverick 4 214 14-Nov-2023, 09:51 PM
Last Post: mstc
  Cleanflight and Emax Skyline 32 V1.2 Tony 1717 16 3,734 17-Nov-2017, 08:46 AM
Last Post: unseen
  Betaflight, Cleanflight, and Raceflight raspberrypi33 8 2,877 03-Nov-2017, 03:05 PM
Last Post: raspberrypi33
  Acro settings? raspberrypi33 8 1,473 03-Nov-2017, 01:58 PM
Last Post: Carl.Vegas
  Discussion Switching from Cleanflight to Betaflight varkokonyi 13 3,750 14-May-2017, 12:27 AM
Last Post: RCFlyer85
