Nazgul won't take off.
Music
Idk if this is the appropriate place to post this but for some reason when my quad does this at max throttle it won't take off and the throttle cuts out. It also has almost zero throttle controll. It will either lag or the throttle will just go to max and the only way to stop it is to disarm it. The USB connector broke off so I have to get a new flight controller before it broke I tried resetting the firmware, adjusting the stick thresholds yet it still does this.
https://imgur.com/mbKFIBH
I'm also using the erls and I made sure that it power was in max. This is the flight controller I ordered.https://shop.iflight-rc.com/electronics-...er-Pro1662
Im thinking that it has something to do with the motor direction. However, I would love yall's input? Note I will not be able to post any betaflight stuff until the new FC arrives.
Your props may be on the wrong motors and/or the motors may be spinning the wrong way so the quad is trying to suck itself to the ground rather than take off.
Perform the following checks:
  1. Use the Motors tab in Betaflight Configurator to check that each numbered slider is spinning the same number motor as depicted on the diagram in the top left of that tab, and that each numbered motor is spinning in the same direction as shown on the same diagram. If you're not sure about the direction, take the props off and put your fingertip lightly on the side of the bell and then spin the motor. Your fingertip will then get dragged in the direction that the motor is spinning.
  2. Make sure your props are fitted to the correct motors. There are two different types of props fitted to a quad and they are directional. The highest edge of the prop blade on each motor needs to be the leading edge when the motor spins.
I only just saw your other post for the same HERE.
Please don't post duplicate threads because different people end up answering the same questions in different threads and the whole thing just gets confusing.
  • hugnosed_bat
(11-Apr-2023, 11:35 PM)SnowLeopardFPV Wrote: I only just saw your other post for the same HERE.
Thank you and sorry. I'm still figuring out how to use the forum.
  Solved SPI V3 ELRS won't bind nicetomeetyou 5 388 23-Feb-2024, 05:22 PM
Last Post: nicetomeetyou
Music Nazgul won't take off. Helltothena4093 2 262 11-Apr-2023, 10:48 PM
  iFlight Nazgul Evoque F5 very bad range polkau 6 1,920 08-Apr-2023, 10:26 PM
Last Post: Cryptonic
  Quad just won't fly stable Helmut585 5 506 17-Feb-2023, 04:24 AM
Last Post: cali_quad
  Solved Quadcopter won't arm. fraq16 9 597 12-Feb-2023, 10:44 PM
