NAZE32 REV6 X4RSB RX NEED HELP WITH CLEANFLIGHFT CLI DUMP@!!!!!!!
[color=rgba(255, 255, 255, 0.6)]please help me get this fpv quad in the air. this is whats in build. naze32 rev6 x4rsb rx Makerfire blheli 12a esc and LHI 2205 2300kv motors. can anyone see whats wrong? everythimg seems to work except motors .[/color]
[color=rgba(255, 255, 255, 0.6)]PLEASE HELP IF YOIU CAN [/color]
[color=rgba(255, 255, 255, 0.6)]2017-01-15 @ 1:35:20 PM -- Running - OS: Windows, Chrome: 55.0.2883.87, Configurator: 1.2.4
2017-01-15 @ 1:35:28 PM -- Serial port successfully opened with ID: 1
2017-01-15 @ 1:35:28 PM -- MultiWii API version received - 1.24.0
2017-01-15 @ 1:35:28 PM -- Flight controller info, identifier: CLFL, version: 1.14.0
2017-01-15 @ 1:35:28 PM -- Running firmware released on: Nov 2 2016 18:29:51
2017-01-15 @ 1:35:28 PM -- Board: AFNA, version: 2
2017-01-15 @ 1:35:28 PM -- Unique device ID received - 0x674ff535753845187093549
2017-01-15 @ 1:35:34 PM -- CLI mode detected
[/color]
Note: Leaving CLI tab or pressing Disconnect will automatically send "exit" to the board. With the latest firmware this will make the controller restart and unsaved changes will be lost.
Entering CLI Mode, type 'exit' to return, or 'help'
# dump
# Cleanflight/NAZE 1.14.0 Nov  2 2016 / 18:29:51 (7a3ded5)
# dump master
# mixer
mixer QUADX
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -AMPERAGE_METER
feature -ONESHOT125
feature -BLACKBOX
feature -TRANSPONDER
feature VBAT
feature RX_SERIAL
feature SOFTSERIAL
feature FAILSAFE
feature TELEMETRY
feature AMPERAGE_METER
feature RSSI_ADC
# map
map RTEA1234
serial 30 5 115200 57600 0 115200
serial 31 0 115200 57600 0 115200
led 0 15,15:ES:AI:0
led 1 15,8:E:FW:0
led 2 15,7:E:FW:0
led 3 15,0:NE:AI:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:AI:0
led 7 0,7:W:FW:0
led 8 0,8:W:FW:0
led 9 0,15:SW:AI:0
led 10 7,15:S:FW:0
led 11 8,15:S:FW:0
led 12 7,7:U:FW:0
led 13 8,7:U:FW:0
led 14 7,8Big Grin:FW:0
led 15 8,8Big Grin:FW:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
set debug_mode = NONE
set emf_avoidance = OFF
set i2c_highspeed = ON
set flashchip_id = 15679511
set flashchip_nsect = 128
set flashchip_pps = 256
set min_check = 1000
set max_check = 2000
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = OFF
set rx_min_usec = 985
set serialrx_provider = SBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set min_throttle = 1040
set max_throttle = 2000
set min_command = 1015
set motor_pwm_rate = 400
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set retarded_arm = OFF
set disarm_kill_switch = ON
set max_arm_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set telemetry_switch = OFF
set telemetry_inversion = ON
set telemetry_send_cells = ON
set frsky_default_lattitude =  0.000
set frsky_default_longitude =  0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set ibus_report_cell_voltage = OFF
set battery_capacity = 0
set vbat_scale = 110
set amperage_meter_scale = 0
set amperage_meter_offset = 0
set multiwii_amperage_meter_output = OFF
set amperage_meter_source = VIRTUAL
set vbat_hysteresis = 1
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 0
set small_angle = 25
set max_angle_inclination = 500
set pid_process_denom = 1
set gyro_sync = 1
set gyro_sample_hz = 1000
set gyro_lpf = OFF
set gyro_lowpass_level = NORMAL
set gyro_lowpass_hz = 90
set gyro_notch_hz = 0
set gyro_notch_cutoff_hz = 130
set moron_threshold = 32
set pid_at_min_throttle = ON
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq =  400.000
set failsafe_delay = 10
set failsafe_off_delay = 200
set failsafe_throttle = 1100
set failsafe_kill_switch = ON
set failsafe_procedure = 0
set acc_hardware = 0
set baro_hardware = 0
set mag_hardware = 0
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SERIAL
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 s 1975
rxfail 5 h
rxfail 6 s 1500
rxfail 8 h
rxfail 9 h
# dump profile
# profile
aux 0 0 0 1875 2100
aux 1 1 1 1900 2100
aux 2 2 1 1375 1600
aux 3 12 2 1300 1700
aux 4 27 1 1375 1575
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 1725 2100 0 0
adjrange 1 0 1 900 1625 0 0
adjrange 2 0 2 1350 1575 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
servo 0 1030 2000 1500 100 -1
servo 1 1030 2000 1500 100 -1
servo 2 1030 2000 1500 100 -1
servo 3 1030 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set yaw_control_direction = 0
set default_rate_profile = 0
set gimbal_mode = NORMAL
set acc_cut_hz = 15
set accxy_deadband = 40
set accz_deadband = 40
set accz_lpf_cutoff =  5.000
set acc_unarmedcal = ON
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf =  0.600
set baro_cf_vel =  0.985
set baro_cf_alt =  0.965
set mag_declination = 0
set pid_controller = LUX
set p_pitch = 40
set i_pitch = 30
set d_pitch = 23
set p_roll = 40
set i_roll = 30
set d_roll = 23
set p_yaw = 85
set i_yaw = 45
set d_yaw = 0
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 20
set i_level = 10
set d_level = 75
set p_vel = 120
set i_vel = 45
set d_vel = 1
set yaw_p_limit = 500
set yaw_lpf_hz = 0
set dterm_lowpass_level = HIGH
set dterm_lowpass_hz = 100
set horizon_tilt_effect = 75
set horizon_tilt_mode = SAFE
set gtune_loP_rll = 10
set gtune_loP_ptch = 10
set gtune_loP_yw = 10
set gtune_hiP_rll = 100
set gtune_hiP_ptch = 100
set gtune_hiP_yw = 100
set gtune_pwr = 0
set gtune_settle_time = 450
set gtune_average_cycles = 16
# dump rates
# rateprofile
set rc_rate = 98
set rc_expo = 65
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_rate = 70
set pitch_rate = 70
set yaw_rate = 70
set tpa_rate = 0
set tpa_breakpoint = 1500
I don't think that your ESC will last long, i see everywhere that they are matched with 20A ESC's, yours are 12A so i think they are going to get really hot if you are going to fly.
Do your ESC / motors make the startup sound?
And edit your post, there is a long space with nothing in it.
[-] The following 1 user Likes Dutch Drone Builder's post:
  • Oscar
@Ikkuh, the long space with nothing in it is his CLI dump. Big Grin (click and drag to highlight it)
If nothing is his CLI dump then we have found his problem Tongue
I saw that he had make a new post in the Brushless micro quad section.
  Share CLI configuration and firmware DarwinFPV BabyApe PRO ap79 4 224 8 hours ago
Last Post: ap79
  UART in CLI Eyes.fpv 3 278 04-Jan-2024, 01:35 PM
  How can I read CLI Eyes.fpv 15 449 09-Dec-2023, 01:24 PM
Last Post: Eyes.fpv
  How to undo changes made in cli PJKMBAKER 5 277 21-Oct-2023, 11:14 AM
  Configuration corresponding CLI command in Betaflight mwon 3 1,000 24-Aug-2023, 11:03 AM
Last Post: zomer
