Naze32 Mini + Beta/Cleanflight
So,
I have one of these lying around: http://www.readymaderc.com/store/index.p...ts_id=4406
The manual says its recommended to use OpenAero32 od Baseflight.
I'm wondering if I could flash Cleanflight (or betaflight) on it without issues. I read some thread
saying the barometer doesnt work well, but i dont mind as i'm planning to use it on a acro-only mini tricopter.
If so, what target would I use to flash it, the normal naze32 hex file?
Huh
It seems to have the same CPU and gyro/accel chip.
I expect the performance to be equal to the Acro Naze board, right?
Betaflight has AFROMINI.hex so it should work. Not sure (I don't use mini), but I think baro issue was fixed - easy to check, but as You said it's not an issue for You anyway.
Ha, nice.
I'll try it once I hit home later
  Help Iflight Seccex-D twin G mini F7 Santhosh_xsb 4 391 07-Sep-2023, 03:42 PM
Last Post: voodoo614
  Help IFlight F7 Mini Wireing question Cantan 3 212 21-Aug-2023, 12:33 PM
Last Post: Cantan
  Help Diatone MAMBA F405 MINI DJI FC default CLI dump or soft serial setup Original 12 2,544 27-May-2023, 12:38 PM
Last Post: Original
  Mamba MK4 F722 MINI backup evkharkov 3 461 08-May-2023, 09:05 PM
Last Post: evkharkov
  Mamba diatone F405 mini mk2 caddx vista osd issues asudhir 2 481 31-Dec-2022, 08:51 PM
Last Post: asudhir
