In Canada, I have been getting many restrictions so I have needed to shrink down the weight. I switched to 130-160 and then the issue of HD video came out :-(.
Runcam split was introduced and then I came across the prop issue in the video. Therefore, I decided to design my own frame to avoid props in my video.
There are few frames in the market you can buy that don't have the prop issue (they are expensive for me). They are not low low profile (which I prefer).
Anyhow, I just wanted to give it a try and design my own frame.
Please consider that I'm a software guy and this is my first attempt and design in this world. I have never down any design in my life.
Therefore, please let me know if I made a lot of mistakes.
I don' have access to CF cutter (even though I purchased the CF sheets) so I cut my frame with Acrylic. Hopefully I will cut it soon on CF.
I just flew with this material (indoor) and there was no issue. Acrylic is really soft.
Requirements of my design:
1) no prop in split hd video in its full FOV
2) no need to have extra hardware to mount camera
3) compatible with 20x20 and 30x30 hardware
4) compact as much as possible.
5) being able to take out the sd card from split 1
6) low profile
So here we go . This is 129mm frame with all components in.
I look forward to getting your thoughts.
6) low profile
