03-Jun-2021, 06:25 AM (This post was last modified: 03-Jun-2021, 06:36 AM by Romine4006.)
I purchased a Aaris Explorer 280 long range 5" quad a couple of months ago. Shortly after getting it i had issues with front right motor not spinning when armed. I swapped ESC around to a working motor and the motor failed to spin so I concluded it was a bad single motor 30 amp flycolor ESC. A month later it arrives and when I install it, it turns out the original motor for that arm was also defective (I should have checked it at the same time) Another month goes by and the motor i ordered is nowhere to be found and cant even track it. I will never buy from Aaris again. I shop GETFPV now. I had 4 smaller motors from another quad lying around so I swapped just the one bad motor before replacing all 4 just to see if it would spin up. hooked up to Betaflight which I have done many times before and get this message "Non betaflight firmware is NOT supported, except CLI mode"
Does this mean I don't have betaflight in this fc anymore?
Do I need to re-flash?
Is this common when ESC's are swapped?
Does having 1 odd motor contribute to any of this?
Any suggestions would be appreciated more than you know. I'm really about fed up with this thing as it seems to be a money pit with no hope of flying anytime soon in sight. I've got over $500 in FPV equipment just setting on a table and I would really like put it in the air. I'm just way over my head with the electronics. Thank you in advance for any help that can be offered.
