Motors not spooling up.....
Greetings all….have had a bit of a brain fart here.  I am nearing completion on my current build and I am having a bit of a problem calibrating the ESC’s……for that matter even recognizing them.  Set up is as follows:
FC: X-Racer v3.1
ESC’s: Flycolor Raptor BLS series 30A
Motors: Emax 2205 2300kv
FC has the following firmware loaded: BetaFlight/X_RACERSPI 3.0.1 Oct 18 2016 / 10:40:35 (48b7b4f)
I am using BLHeli Suite 16.514.8.0.0
Problem……motors will not spool up.  Trying to access them through Betaflight they just act like they aren’t there.  I think pass though is working, but when I try and use BLHeli to read or check the current version on the ESC’s I get the following error:
The motors remain completely still and silent until I turn the transmitter on.  As long as it’s on, Motor number four will twitch and slowly revolve.  Doesn’t matter if it’s armed or not. I suspect I am doing something really stupid and if someone could point that out to me I would be grateful.  Thanks Guys!!
Sirdude, I just looked at your build thread again. You've got your esc's connected to the wrong side of the XRacer FC. Should go to the PWM1-4 instead of CH1-4.
  • Grisha0, sirdude
Ok...well that' s embarrassing. I even thought that and went back and looked at the diagram in the manual and miss read it a second time. I don't believe I did that. Thanks Scotty...with mistakes like that, I think I'm gonna take a break from quad building for a while. Thanks for getting me straight.
(18-Dec-2016, 03:44 AM)sirdude Wrote: Ok...well that' s embarrassing.  I even thought that and went back and looked at the diagram in the manual and miss read it a second time.  I don't believe I did that.  Thanks Scotty...with mistakes like that, I think I'm gonna take a break from quad building for a while.  Thanks for getting me straight.
Almost did it myself (same board).  Don't feel bad, and don't stop now - it's close! Smile
Ahahah I was there yesterday while changing one ESC set to another. All ESCs placed, + - and motor wires soldered up, checked ESC numbering, chopped motor 1 signal ot length, pulled my soldering iron, grabbed pincers and WTF? why arent there any soldering blobs on those pinholes?
Oops it says CH1 xD
Same board BTW ;p
[-] The following 2 users Like KonradS's post:
  • sirdude, sloscotty
  one of the motors does not arm balabushka 4 114 01-Apr-2024, 09:54 PM
  Skystars 1404 motors (any kv) Pathfinder075 16 694 14-Mar-2024, 10:56 PM
  Solved 2004 3000kv motors on 6s Mad35 6 222 12-Mar-2024, 06:05 AM
Last Post: Mad35
  YSIDO MOTORS hawk01 2 536 16-Jan-2024, 06:14 AM
Last Post: hawk01
  ESC on AIO got silent and not spinning motors. Everything else looks fine. maxer 12 442 16-Dec-2023, 10:16 AM
Last Post: maxer
